It is currently Sun Aug 17, 2025 12:00 pm
 Post subject: Original Engine?
PostPosted: Thu Sep 22, 2005 4:16 pm
Hi, Can anyone tell me if the engine number 8AM/U/H is a UK built or Australian built engine?
This is the engine number that was on the Traveller, we're trying to work out if this is the original engine or its been replaced?
Thanks
Janelle :D
I swerve and hit people at random.
PostPosted: Thu Sep 22, 2005 4:23 pm
if it matches your plate then it's the original
PostPosted: Thu Sep 22, 2005 4:27 pm
Cush, Its says See Engine on the plate.
PostPosted: Thu Sep 22, 2005 4:35 pm
it's an 850 motor.... since it's a UK build, you ought to be able to get a heritage certificate done for it, I think they have records of what engine in what car
PostPosted: Thu Sep 22, 2005 4:58 pm
going by
http://www.hotbricks.org.au/
Technical Tips
its an Australian Engine
PostPosted: Thu Sep 22, 2005 5:09 pm
8AM/U/H 848 YMA2Sl Morris Mini Saloon (A)
8AM/U/H 848 YJBAV2R Morris Mini Van (A)
The A means Aussie :D
http://www.hotbricks.org.au/files/engine.txt
Roads need more corners
PostPosted: Thu Sep 22, 2005 5:11 pm
It's in an Australian car, but the early 850 motors were all imported. Not much Oz content in these motors, until the Mini Deluxe. :wink:
I was hoping the [A] at the end of that number at that web site did not mean australian, I was hoping that we had the original engine.
Thanks for the bad news gafmo
PostPosted: Thu Sep 22, 2005 5:15 pm
In my list it just says 8AM prefix used on Austin/Morris 850 from 25,000 on. So IMO that makes it UK made (as we never got Austin). :wink:
The engine is out of the 64 all steel traveller which is uk built.
PostPosted: Thu Sep 22, 2005 5:16 pm
8AM was used both here and over there.. my `62 850 had that prefix.
PostPosted: Thu Sep 22, 2005 5:41 pm
Thanks Doc,
In saying that, If we have it restored are we safe to say that it is a Restored Original if we retain this motor?
Janelle
PostPosted: Thu Sep 22, 2005 5:46 pm
Does the body number match up with what hotbricks says?
PostPosted: Thu Sep 22, 2005 5:47 pm
Is the engine number stamped into the block or on a plate riveted to the block. A lot of UK ones have the riveted plate, but if the car was SOLD in australia it would have had the number stamped into the block. The POMS must have been more trusting back then eh?
PostPosted: Thu Sep 22, 2005 6:21 pm
No my number starts with G hotbricks all start with y.
mickmini
The number is stamped but you can see where the rivets were.
Users browsing this forum: Bing [Bot] and 333 guests
