It is currently Sun Aug 17, 2025 9:49 am
 Post subject: Brake pads
PostPosted: Thu Sep 22, 2005 6:59 pm
Was wondering - If I replace my current pads with some greenstuffs but leave the old rotors on, in a few months time when I decide to replace the rotors too, would I be able to keep using the same greenstuffs pads or does a rotor change always neccesitate a pad change too? (I just know that its common to swap the pads when disks are changed \ ground).
Oh and where can I get some anti squeel shims for the 7.5'' disks?
 Post subject: Weeell...
PostPosted: Thu Sep 22, 2005 7:07 pm
The answer is you should use a new set of pads with your new rotors so that they bed in to the new surface...however...a few months of sympathetic driving on old wavy rotors probably won't matter :D
Just be prepared to take it easy whilst everything sorts itself out and for some initial vibration at the pedal while the pads sort themselves out :D
PostPosted: Thu Sep 22, 2005 7:09 pm
You can keep the same pads. Give to me and I'll dress them flat again.... 8)
You don't really need anti-squeal shims for most current pads. Some pads have a soft layer of some sort on the steel backing.
I'm running Greenstuffs with no shims on Ha-Ha and Blackstuffs on Barney, none there either..
No problem. :wink:
PostPosted: Fri Sep 23, 2005 3:07 am
Cheers Doc, everything seems possible when you're around.
Users browsing this forum: No registered users and 337 guests
