It is currently Fri Jul 18, 2025 12:22 pm
PostPosted: Wed Aug 11, 2004 12:30 pm
http://www.triumphspitfire.com/substitute.html
David L
PostPosted: Wed Aug 11, 2004 1:41 pm
Sweet! I like the bike brake cable as a replacement for the heater cable... Never thought of that!!! :shock: :D
PostPosted: Wed Aug 11, 2004 1:48 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
also good for the accelerator cable i've had yellow blue green red and a few other colours
and at 4 bux you can change em with ya mood
makka
PostPosted: Wed Aug 11, 2004 10:34 pm
i think we should put together a list like this for minis. add the pulsar distributor and dizzy and also the honda brakes.
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Thu Aug 12, 2004 1:22 pm
How about using the heater cable as a throttle cable in an emergency? I've seen that done, and you get cruise control as well! I've tried using the choke cable as a throttle cable once but it is a little hard to drive ;)
Anto.
PostPosted: Thu Aug 12, 2004 2:06 pm
Gemini starter motor is another interchangable mod.
PostPosted: Thu Aug 12, 2004 8:53 pm
Won't fit in though, if you got an S oil cooler in the usual place in a roundnose..
They are a pre-engaged starter- the integral solenoid sticks forward a bit.
PostPosted: Fri Aug 13, 2004 3:48 am
Anto.
I never liked the idea of criuse control....
When the c/c is ON, where do your feet go?? On the floor away from the brake pedal?? Wouldnt that drastically reduce your braking reaction time in an emergency??? I mean, you gotta lift your foot back over the pedal first...... and in the confusion - is that the accelerator???? UH OH!!!
Unsafe.
And fuggen lazy too. If ya dont wanna drive, get in the passenger seat ya lazy biatch...... sorry... havin a flashback.... :roll:
PostPosted: Fri Aug 13, 2004 11:03 pm
I'm happy with with mine.
Does the oil cooler bolt onto the chassis or the block? I wonder if you could mount it further across? I spose the alternator is going to be in the way.
It's a pretty simple decision in the end. If you're on the track you only need to start the car once but you want the oil at a reasonable temp. For a road car you want reliable starting but oil temp is not such an issue
dewey
dwightgunning.com
 Post subject: oil cooler
PostPosted: Sat Aug 14, 2004 12:27 am
mount the cooler on the chassis... less movement and vibration
embarressing when the cooler breaks off and leaks everywhere
PostPosted: Sat Aug 14, 2004 6:36 am
I've tuned a few race motors with these starters- I don't think their torque is much better than a good Lucas one. Starter body hardly any bigger than Lucas...
I kept the S cooler, bought a UK reco'd Lucas starter, and put a Landcruiser battery (550CCA) in.. :P
