It is currently Fri Jul 18, 2025 9:26 am
PostPosted: Fri Sep 30, 2005 8:47 am
you can get the camira into 12s but you have to grind alittle
Twincam GTi Powerd mini
PostPosted: Fri Sep 30, 2005 8:55 am
MiniGTI wrote:
Thanks Mate, why would the booster cause them to lock up easily also what is the pedal pressure like. :?: :D
well I guess without the booster you have more control on the point of lock up. I think that?s why allot of race cars don?t run boosters. but ill try it one of these days. I drove josh's car yesterday with the Honda?s and boosted felt really nice. :D
pedal pressure is hard. not spongy like the cooper S. basically its like your average new car to pull up.
PostPosted: Fri Sep 30, 2005 11:55 am
My understanding is that the Booster is mandatory for conversions in NSW...
Brad had too in his car... & he has the 4-pot Ventelated Metro ones...
I will get my engineer to confirm... thanks
Baracade
PostPosted: Fri Sep 30, 2005 12:05 pm
Same here. I wanted unboosted, but must have a booster as it was fitted as "an original safety item" with Subie disks.
The only way you can get away with fitting unboosted discs AFAIK
would be to use discs that were unboosted in their original application.
PostPosted: Fri Sep 30, 2005 1:11 pm
just plug up the vaccuum line. they'll never know
grind what?
I have m/c discs so that the caliper mount has about 2mm clearance to the hub. DO you mean grind the rear of the caliper mount to clear the hub?
PostPosted: Fri Sep 30, 2005 1:35 pm
I had to grind a tad off the outside of the calipers themselves to fit the Subies under my 14"s
PostPosted: Sat Oct 01, 2005 10:16 pm
thats what you have to do if you wont to fit them into 12 inch wheels.
