It is currently Tue Jul 08, 2025 7:12 pm
Which engine?
Poll ended at Fri Nov 04, 2005 11:02 am
B16A 17%  17%  [ 1 ]
B16B Type-R 83%  83%  [ 5 ]
B18C Type-R 0%  0%  [ 0 ]
Other (Specify in post) 0%  0%  [ 0 ]
Total votes : 6
PostPosted: Tue Oct 04, 2005 11:02 am
Hey all,
I was wondering if anyone would know what kind of suspension/brake setup to use whilst setting up a Vtec mini??
Also wondering if anyone in Australia has done this conversion or is trying to complete one? If so what subframe are you using?
Adam
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Tue Oct 04, 2005 6:25 pm
b16a or B would be the choice...
As then you have the choice of going turbo later!
if you go bigger you wont be able to get it Engineered in NSW
Baracade
PostPosted: Tue Oct 04, 2005 9:43 pm
The B16-b is the best motor by far,
but for the same reason you will be lucky to find one
even at a horrendous price :(
You might find you could afford a B16-a and a turbo for the same price.
 Post subject: Whats the difference?
PostPosted: Wed Oct 05, 2005 11:42 am
Hey, Thanks for the replies.
Whats the difference between the B16A and B?
Also i'm looking into the brake situation, which conversion does anyone recommend for this type of engine conversion? Honda, Camira, 'S' ??
Cheers for the info. :D
I smile everytime!
PostPosted: Wed Oct 05, 2005 9:19 pm
The B16b is found in the Type R - it's the ultimate in Honda 4s :D
Lots of details here:
http://tech.hybridgarage.com/tech/bseries.html :wink:
PostPosted: Wed Oct 05, 2005 10:00 pm
Oh, and I would stick with the Honda theme for the brakes
but I have read that the Camira brakes are cheaper & at least as good.
