It is currently Wed Jul 16, 2025 11:22 am
PostPosted: Fri Oct 07, 2005 3:24 pm
Hi
Just wondering if anyone could tell me what it takes to convert to dry suspension??
Do i just have to find a dry front and rear subframe and swap them over or is there more to it
thanks
PostPosted: Fri Oct 07, 2005 3:28 pm
yea you do pretty sure we were just talking bout in another thread
PostPosted: Fri Oct 07, 2005 5:36 pm
Stay Hydro..it is Better syspention :wink:
I have one of each......have a drive around in someone else dry...and you will enjoy the differance 8)
PostPosted: Fri Oct 07, 2005 5:55 pm
reading some other posts they sound like a lot of trouble.
owned a van once with dry and it was'nt to bad.
I read some other posts but they dont say if its a clean swap of the subframes,
or do you have to change something for the shocks to fit
PostPosted: Fri Oct 07, 2005 6:44 pm
No idea mate...but I believe it will be more trouble than its worth
PostPosted: Fri Oct 07, 2005 7:21 pm
You can keep the wet subframes. And the top arms. :)
And the rear arms too- but the axles would need pressing out & changing to dry type so you can mount the lower end of the shocks. Easier to find some dry rear arms...
There are lugs inside the wet subframes to locate the hydro displacers- these need to be butchered a bit so the rubber cones will fit in instead. Then add a set of Hi-Los for height adjustment (or some dry trumpets) and away you go.
Oh- you will need some front shock mount brackets too, and drill the top arms out for the 3/8" shocky bolts.
I have a wet car (now with front shocks), and a dry one converted to wet. I do wonder why the P/O bothered... :cry:
PostPosted: Fri Oct 07, 2005 7:42 pm
you can grind slots in the base of the rubber cones to fit in the lugs, so you can go back to wet at a later stage when you decide your back has had enough....
PostPosted: Fri Oct 07, 2005 8:06 pm
Dr mini
so thet top arms on the wet are the same as the dry apart from the size of the shock bolt is that right ?
Thanks mate
PostPosted: Fri Oct 07, 2005 8:25 pm
sunburst wrote:
Dr mini
Thanks mate
Almost. The lever ratio is less (so suspension is a little stiffer) with the wet arms. But they handle better. Old UK racers trick.... :wink:
PostPosted: Fri Oct 07, 2005 8:37 pm
One damn good reason is - If you don't live in or near one of our capital cities, there is nowhere to go and have the system re-pressurised every time you do some work on the suspension or play around with ride heights.
Much easier to convert to dry with hilos, so that you can play with the set up until you get it right. Then set and forget. :wink:
Curly
PostPosted: Fri Oct 07, 2005 8:44 pm
Then you just make a pump out of a master cylinder.
PostPosted: Fri Oct 07, 2005 10:37 pm
As you do.. (I did) when you get sick of driving 8 miles & paying $50 for a pump up.. :lol:
PostPosted: Sat Oct 08, 2005 9:08 am
i had my mini k converted to dry at link auto, with exchange of my old wet frames i got the dry suspension setup for $1500ish with hi lo's and new shockers etc. i was so sick of the hydro that i cut them up and put valves on each one so i wouldnt get the pitching in acceleration. it made it better but i've always liked dry suspension.
Users browsing this forum: Bill B and 71 guests
