It is currently Sat Jul 19, 2025 5:39 am
 Post subject: stepped drums
PostPosted: Fri Oct 07, 2005 8:04 pm
how much do stepped drums offset your wheels?
Do you need longer wheel studs or is there a different flange?
Do clubman flanges (rear to suit stepped drums) fit a roundnose?
thanks
PostPosted: Fri Oct 07, 2005 8:51 pm
1. They don't offset your wheels, they increase your track by the width of the step on each drum. If I recall correctly, the Cooper 'S' ones are about 3/4" on each drum so that makes the track 1.5" wider.
2.Yes - longer studs, they fit into the standard hub flange.
3. Yes.
Curly
PostPosted: Fri Oct 07, 2005 11:03 pm
Big wheel Moke drums are 3/4" wider, Cooper S Or Clubby S ones are 1"... as I found when I bought a Moke one by mistake once. :cry:
PostPosted: Fri Oct 07, 2005 11:36 pm
it's an easy job to change them over, did it myself with just a BFH and some screwdrivers.
PostPosted: Sat Oct 08, 2005 2:04 am
I got moke ones and only found out their 1/4" smaller after I got them machined and linnings to suit and to make it worse it would of been cheaper to buy new cooper S ones and linnings :oops:
Doc do you reckon the moke ones will be ok as the front will have drooper S brakes?
67' Matic
73' S
PostPosted: Sat Oct 08, 2005 7:00 am
Depends what wheels you use at front. S steel wheels will foul. LS offset Contessas will foul. :cry:
Mini offset Contessas, Hotwires, or Jellybeans will clear. :D
PostPosted: Sat Oct 08, 2005 12:44 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
hey ive got 2 sets of 1" steped drums, came on the clubby that i stripped, was stoked when i saw them,
1 pair going on the rear of the van!
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
