It is currently Wed Aug 06, 2025 8:06 am
 Post subject: Dropping doors!
PostPosted: Sun Oct 09, 2005 2:20 pm
Is it an easy task to adjust the doors using the bolts under the Hinges??????????
Am having issues with water coming over the top of the door it isn't sealing properly!
PostPosted: Sun Oct 09, 2005 3:03 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
do you have to lift up your doors to shut them properly?
is there excess play in the hinges, wiggle the door up n dowm, there should be nearly no play at all,
if so, buy a new HINGE PIN KIT (replaces the pins in the hinges without touching bolts in doors, or panel
if both the above is fine, try new door rubbers,
blake
:wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Sun Oct 09, 2005 5:58 pm
yep! Thats the prob shall give that a go! thanx
 Post subject: Hinges
PostPosted: Mon Oct 10, 2005 8:44 pm
Sometimes the hinges are too far gone for the standard bushing kit (around 50 bucks)....search ausmini for this subject and you will see that others have had to drill bigger holes and use far bigger bushes then standard to correct the problem.
PostPosted: Mon Oct 10, 2005 8:47 pm
Shall do! Have had to put that job on hold am going away to merimbula. Is definately on the to do list though!
Thanx
:D
 Post subject: Mexicans!!
PostPosted: Mon Oct 10, 2005 10:00 pm
What is the attraction for Mexicans around Merimbula...they descend like locusts :lol:
PostPosted: Mon Oct 10, 2005 11:43 pm
just finished removing and refitting my passenger door to replace black plastic gaskets under hinges.To adjust the door position you have to take off the door trim and alloy kick plate for access to the hinge bolts and the removal off the front wheel helps if the hinge parts inside the wings need attention. I lightly loosen the hinge bolts and nuts and lift the door into positionand re-torque . I find loosening the door hinge nuts and then walk the door around the door cutout ( usually lifting the door at the lock end ) using the screws on the front of the door hinges to hold the door in position while retightening all nuts and bolts. Watch the paint work doesn't get chipped while closing the door.
68 Deluxe. All the Options and Mods. Bling-Bling.
Users browsing this forum: fuzzy-hair-man and 68 guests
