It is currently Wed Jul 23, 2025 6:48 pm
PostPosted: Wed Oct 19, 2005 5:05 pm
Hey,
the plans for my respray are well in swing, now all i need to buy are the following:
- New seams (covers?)
- A set of door hinges (both doors)
- New trim (plastic chrome) that runs down the side (wheel arch's and
beneath the doors)
- Bullet mirror
- mk 1 Cooper S badges (morris cooper s) bonnet and boot
- Moustache grill surround
- New Grill
- Bumpers with overriders and corner bars
- Steering coloum
Where is best?
PostPosted: Wed Oct 19, 2005 5:08 pm
Us "old" folks shop around for a bargain. Have a look in the howto section for the list of sellers. Call them ask for the prices on the parts and choose the one you like. :wink:
Aaro
PostPosted: Wed Oct 19, 2005 5:11 pm
I can definetely help you out with seam covers. And maybe steering column/grille bits. Otherwise you can find most of that other stuff at the places listed in the HowTo forum or even Ebay.
PostPosted: Wed Oct 19, 2005 5:15 pm
Ask your Father. :lol: :lol: ROFL :lol:
PostPosted: Wed Oct 19, 2005 5:20 pm
I'd just add that buying 4 new door hinges is not usually necessary, it's way cheaper to buy new hinge pins & bushes from one of the Mini parts purveyors.
I tend to use the one that starts witk `K.......' 8)
They are not hard to fit- all you need is a BFH, a 1/4" pin punch, a block of hardwood, and a bench drill. :wink:
Don't try to fix them ON the car....... :shock:
<edit> you should also get the proper rubber gaskets that go between hinges and body/door...
 Post subject: Spacers....
PostPosted: Wed Oct 19, 2005 5:42 pm
And make sure you have the correct washers and angled spacers for the hinge studs inside your doors so that you are tightening the hinges at 90 degrees (to avoid rippling of the door skin around the hinges)
PostPosted: Wed Oct 19, 2005 6:00 pm
does "Company K" ;) do hinge kits?
and how much? i can't actually find mk1 door hinges on CompanyK.com.au
edit... DER!!! all aussie doors are externally hinged....
here i am going... ew.. mini clubman hinges...dont' want those... where are the mk1 hinges... :roll:
PostPosted: Wed Oct 19, 2005 6:15 pm
Company 'K' lists them as clubman hinges cause they're better :P
PostPosted: Wed Oct 19, 2005 8:54 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
- New seams (covers?)front l+r bmp127 $15.19 each rear lh bmp125 $17.53 rear rh bmp124 $17.53
- A set of door hinges (both doors) could not find
beneath the doors) get from bunnings or simuler
- Bullet mirrorgam105$56.91 personally i think they are crap
- mk 1 Cooper S badges (morris cooper s) bonnet and boot24a72 64.9< bonnet boot 24a24$85.32 the little s is 24a1401 $14.96 each
- Moustache grill surround14a7781 188.76 extensions lh 14a7783 $23.68 rh 14a7782 $23.68
- New Grill mk1 is24a2158 195.72 austin coopers style 24a198 $218.16
- Bumpers with overriders and corner bars do you want chrome stain less original copy ??? the coopr s style are 14a9871 $185.71 i think that is for the front an rear not 100% sure though
- Steering coloum not listed unless you mean the rack
all parts are availible from the K place ie shhhhhh dont tell anyone i told you cos it may get me in crap
Karcraft
10 eggerton st
silverwater nsw2128
ph 9737 9944
fax 9737 9011
dont forget 02 if ya out of nsw
and i appologis for being in sydney and being apart of this so called click :(
makka
PostPosted: Wed Oct 19, 2005 9:02 pm
Thanx makka, best answer anyone has ever givin me
I dont get the sydney click thing, or why its called the k-place :?
i guess i missed some stupid argument or something.
PostPosted: Thu Oct 20, 2005 6:26 am
Ryan
Karcraft have a great website on which you can get quotes via email and for very little extra they will courier it to you.
steve
Users browsing this forum: 78Clubbie, Steam and 105 guests
