Mini Mad wrote:
lobby69 wrote:
for a fresh motor, go for good new quality oil, like magn atec, mobil 1 fully synthetic,
Both those are pretty bad for a mini..
As for the bike stuff, i suppose it could be OK, being made for bike gearboxes and stuff, it is 20w50 as well..couldn't find anywhere that said it is..
Castrol Formula R is the best stuff though, it even says it's good to use in cars that share the gearbox.
I agree with Mini Mad, also I'd suggest that putting synthetic in a NEW motor, it'll never bed in properly.
As said, I use Valvoline SF 20W/50 for new rebuilds, GR uses a cheap K-Mart 20W/50 (made by Shell).
Both do the job. Dump it and the filter after 200-500 miles and Refill with the same. At the next change use whatever you fancy- but remember, Minis are designed for 20W/50 not Mobil 1 etc.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
