It is currently Sun Jul 27, 2025 9:04 am
 Post subject: cam ID
PostPosted: Mon Oct 24, 2005 6:36 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
hey lads,
just trying to find out what cam i pulled out of the 1132....
there are no numbers on the cam at all, but it does have 2 machined bands in it at one end,
can anyone ID that cam?
any rules about can ID for future references???
cheers and thank heeps, blake
:wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Mon Oct 24, 2005 9:34 pm
If 3/8" lobes it's just 1100 cam.
5/45-51-21.
12G165 or AEA630.
According to Mr Vizard...
Of course it may have been reground since... could be anything now really. :lol: One of my S cams has been reground 3 times and then freshened up once... :shock:
 Post subject: Re ground Cams
PostPosted: Tue Oct 25, 2005 6:16 am
Usually re ground Cams have a number stamped on the threaded end. Different Cam grinders have different Cam grind numbers. Unless you know who exactly ground it , you cannot find out what profiles it has till you put it in a machine and measure Lobe lifts and duration etc.
PostPosted: Tue Oct 25, 2005 6:44 am
It's usually obvious if stock & never been reground- standard smallbore cams have pointy lobes and a lot of metal on the base circle (the round part) of the lobe. Nice for regrinding.... :lol:
If you don't know what it is just get Russell Engineering (or whoever) to regrind it to a good known profile..... :wink:
