Dunno why people would misunderstand them, I found them a lot easier than an SU.
With an SU you have to buy dozens of needles to try. They are not in a logical numerical sequence, lean to rich. Too many variables to get the right setup. You can only get it close without filing needles.
With a DCD/DGV etc you buy a few main jets and try them. Need more fuel, go up a number or two on the mains. Need less fuel, drop down a number or two. The jets are in a logical sequence 125, 130, 135,140 etc. Tune primary 5-10 leaner for economy.
Fine tuning at the top end can be done with the air corrector jets. Air correctors work in reverse - smaller jet = less air so more fuel and a richer mixture.
If you want to get really accurate play around with different emulsion tubes and pump jets too. It was all available over the counter at my favourite speed shop (Stree Performance in Beverley Hills, Sydney). Back in the early 90's the jets were about $1 each. The carbs were approx $40 off any 2litre Escort or Cortina.
Only disadvantage I can see is the manifolds are a bit restrictive.
If it hadn't been for the complexities of hooking up the Auto kickdown to the Weber, I would have bid on it for my Moke.
