could be the fact that they are non genuine pads for the car.....
with volvo at work we get alot of non genuine pads fitted to them.....the customers come in complaining of brake squeel, hrd pedal pressure and lack of performance,
also with land rovers....aftermarket pads actually cause a really high pitch squell (which we cant hear) but the squell actually buggers up the ABS sensor and causes the ABS light's to come on the dash, change to genuine pads...alll good again,
as for FERODO pads, we have used 2 set sofar on the KAZZY69 charade
and we have done over 60,000ks, and the car does cop a hard thrashing and hard braking,
if only one pad has worn badly (in each caliper) it could be that the FLOATING pins in the caliper arent sliding freely and causing the piston pad to wear faster than the caiper pad (if thats the case...)
blake
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE
yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
