It is currently Sat Jul 26, 2025 11:25 pm
Post new topic Reply to topic  [ 140 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 10  Next
PostPosted: Sat Oct 29, 2005 8:28 pm
This is the factory original GT steering wheel you need Anton. It has a small Leyland symbol in the middle.
Julie.............
PostPosted: Sat Oct 29, 2005 8:47 pm
Cool!
is that wheel upside down?
I have a MINT one of those center pads. It wasn't only GT's that got that style wheel was it?
PostPosted: Sat Oct 29, 2005 8:52 pm
it's not upside down mate, the wheels are just pointing either left or right, i can't tell from this angle... :shock:
Yes i am a dad and i like bad dad jokes :roll:
Aaron
PostPosted: Sat Oct 29, 2005 8:54 pm
J_A_M wrote:
Cool!
Yeah - too many Bourbons!
Julie.............
PostPosted: Sat Oct 29, 2005 9:05 pm
hehehe....obviously!
:P
PostPosted: Sat Nov 05, 2005 11:58 am
I recently aquiered an accident damaged clubman shell - no front
Hydrolastic suspension.
Spot welded mounting points for RH fuel tank. (not bolted behind seat)
Pop rivit holes where the boot board mounts were.
Original kermit bright green.
And the following numbers behind the master cylinders.
M2
23
1162.
Is this a Clubman GT body - what do the numbers mean?
PostPosted: Sat Nov 05, 2005 3:27 pm
M2
23 is GT. What's the rad shroud say? YG2S ? ####
PostPosted: Sat Nov 05, 2005 4:50 pm
J_A_M wrote:
M2
I'm guessing that if doesn't have a front on the car then there would be no comp plate or rad shroud. Shame.
Julie.............
PostPosted: Sat Nov 05, 2005 6:28 pm
:oops: ....silly me.....I read that but it just didn't click..... :P
IMHO, if the plate and rad shroud is missing, it aint the real deal......even if it WAS a 100% GT. :(
Look for other small signs it was a GT. Under the rear seat, on the upright panel, there should be 1 pop rivet on the passenger side of that panel. Apparently for the elec fuel pump. :wink: No rivet or evidence of one previously being there, possibly not a GT.
PostPosted: Sat Nov 05, 2005 8:54 pm
It's a breather for the electric pump, can't recall if it's a `pop rivet' though..
If wiring loom remains are in the car there will be a wire in the back part that feeds the fuel pump. No other Clubbys had that wiring. :wink:
PostPosted: Sun Nov 06, 2005 9:05 am
AS the DOC says it's a breather for the electric pump. It's not a pop rivet but a type of PUSH rivet like they use on most new cars these days to hold all the plastic bits together. It has a hollow stem that connects to the pump breather pipe. The hole under the seat is about 1/2" dia.
I think most OZ built minis that used the rear subframe mounted SU electric pumps had the breather. Real early Minis used a different electric SU pump, a PD? type, not the later AUF type. Don't know if the PD type used a breather.
Regards
RonR
PostPosted: Sun Nov 06, 2005 9:09 am
I had an early 850 with PD pump- no they had no breather. Most 850s then got the AUF pump because the PD was a POS and was not repairable either.
PostPosted: Mon Nov 14, 2005 10:20 am
what is the correct carpet colour for a GT?
PostPosted: Mon Nov 14, 2005 4:56 pm
The same colour as the interior trim and the seat belts.
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Mon Nov 14, 2005 8:22 pm
Cool, thanks for that.
Might have to be "shoes off" in my GT then...with carpet that light in colour! :lol:
