It is currently Sat Jul 19, 2025 11:34 am
 Post subject: more power !!!
PostPosted: Sun Oct 30, 2005 6:16 pm
i currently have a 1974 mini clubman. had it 3 days now. i have a small budget as im nly 17 with this beeing a first car. i want more power from the lawn mower engine without adding webbers ( kuz im broke ), turbos or supercharger. the clubby currently has a new clutch and all new cv joints.
im thinking of installling extractors with a cannon smaked on the end if that would help.
any other help would be appreciated.
thanks for the help.
PostPosted: Sun Oct 30, 2005 6:40 pm
dont fit a cannon, wont do nothing for performance, go to a mini specialist and get an exhaust, you can get stage one kits for reletively cheap which give a 20 percent power increase to your 998 or 1100 engine (dunno what it is) and just a decent service, new spark plugs, lead etc should help u get a bit more power from ur brick :wink:
sean
Potato
PostPosted: Sun Oct 30, 2005 6:57 pm
yer i have put new leads o it aswell as new sparkies, so cannon is a bad idea aye. damn, i want a loud noise from the exhaust tone. its a 1100cc . i piked the clubby up for 400 buks off my cousin who is a mekanik so its in pretty good nik engine wise.
can u pik up them from a mini wreckers instead of a specialist. ther is a mini wreckers neer me so yer
PostPosted: Sun Oct 30, 2005 7:06 pm
if you have an 1100 and its standard id say it would have a 1 1/4 su your best option for power if this is the case is to get a 1 1/2'' su and manifold and a set of 3into 1 extractos this should give you a noticible increase and im sure someone would have some spare.
also put you location in your profile :wink: hope this helps
PostPosted: Sun Oct 30, 2005 7:19 pm
yer i was thinkin of a bigger carby with extractors and all. with the exhaust. what size would you recommend? im a newby to mechanics so im tryin to learn. i appolgize in advance if i ask something simple or dumb. :? is it woth putting bucket seat in. if so what ones u recommend and do u rekon u kan get them from the wrekers cheaply.?
thanks for ur help man.its helpin
PostPosted: Sun Oct 30, 2005 7:22 pm
Well it does depend on your buget :!: Head, Carb and Cam Not in that ordes for straters :idea:
Congrats wand welome :wink:
PostPosted: Sun Oct 30, 2005 7:31 pm
i have got another question aswell. i think i need new valves or rings. the car blows a fair amount of smoke when accelerating. its not running rich. too much smoke n crap. lots of carbon throughout the oil and sparkies even with the sparkies being relatively new.
what u rekon?
PostPosted: Sun Oct 30, 2005 7:42 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
harvey first really good bit of advice anyone on here can give you is
DONT LISTEN TO MEENI .....
next bit of advice is to save some cash
then fix things as you can afford to mate
makka
PostPosted: Sun Oct 30, 2005 7:59 pm
makka
I 2nd that
Aaron
PostPosted: Sun Oct 30, 2005 9:18 pm
You will not gain any power with a cannon, in fact you'll probably lose power. You want a 1.75" Exhaust, no bigger. You can get a 1.5" carb for peanuts and keep your eye out for some 3into1 extractors. That should keep you happy for a bit until you save some more cash :)
PostPosted: Sun Oct 30, 2005 10:20 pm
if you want a cannon just cause you think it will sound loud you got the wrong idea my exhaust is louder than most tuner cars with a cannon. just get some LCB extractors and sports exhaust then later on bigger carbie after that the list goes on and on thats what stage i am at, the list goes on and on......
PostPosted: Sun Oct 30, 2005 10:27 pm
me and my mate where were doin some media trials with a dv cam, i filmed his nissan silvia with a 4 inch cannon, goin around an S bend at 100km. Then i did the S bend in 3rd gear in my 1100 clubby. The bad boy mini, was by far the most loadest over my mates 4inch siliva. And he admitted to it as well. And we have the footage too. :lol:
And i run LCB maniflo extracters/heads. 104 cam, 1.75inch straight thru to muffler -> 2.5inch tip.
twista
Image Image
PostPosted: Sun Oct 30, 2005 10:37 pm
if you want a beefy tone, go a 2 inch into a cannon..
if you want a rorty tone, go a 1+7/8 and straighthrough..
exhaust, extractors, and bigger carb plus a good tune.. should go pretty good.
valve seals might need replacing, oil leaks through them making the engine smokey..
PostPosted: Mon Oct 31, 2005 7:53 am
makka
get the fiddle sticks over it makka
Potato
PostPosted: Mon Oct 31, 2005 9:53 am
yer i was thinkin it was the valve seals. the only other thing i thought it coulda been was the rings.
thanks for the help wid the exhaust. i atleast know what im lookin at now.
she should look good whe she is resprayed and given a bit more balls.
