It is currently Thu Aug 14, 2025 12:08 am
 Post subject: Oil plug leak?
PostPosted: Tue Nov 01, 2005 11:15 am
Is oil leaking from the oil plug a standard mini problem?
My plug has 2 aluminium washers that look stuffed, is this the standard washers.
Anybody with any clues to fixing this, please help as I what to do an oil and filter change.javascript:emoticon(':)')
PostPosted: Tue Nov 01, 2005 11:19 am
I presume you're talking about the sump plug.
Just take the plug out, walk to Supercheap, Repco, Autobarn, Autopro, or whoever is around and get a new copper washer from the bolt stand. Comes in those little packets the bolts come in.
Blackwoods would have them over the counter as well.
Should cost less than a dollar.
PostPosted: Tue Nov 01, 2005 11:21 am
I use a new copper washer every second oil change
after that, they will usually leak
PostPosted: Tue Nov 01, 2005 6:00 pm
Yes, the 'SUMP' plug, sorry mental blank! :oops:
I was in a hurry when I posted cause I was going out and I thought one of you guys would have the answer by the time I got back and you did.
Thanks heaps. :D
PostPosted: Tue Nov 01, 2005 6:06 pm
if it still leaks put some teflon tape on the thead i think maybe :? someone will know what type
PostPosted: Tue Nov 01, 2005 6:39 pm
Teflon tape is not a great idea... it can get in there and block things up.
Our Clubby has a leaky sump plug `coz some deadbeat put a helicoil in, crooked... :x
So whenever it needs a change now, I wipe the plug threads and put a couple of drops of Loctite 515 or 518 Master Gasket on them. No more leak... and it's still easy to remove. 8)
PostPosted: Tue Nov 01, 2005 7:19 pm
Resident Haemorrhoid
Tim B asked
Is oil leaking from the oil plug a standard mini problem :?:
Reply
No its only marking its territory :wink:
mtsmini wrote:
Tombo wrote:
Users browsing this forum: No registered users and 261 guests
