It is currently Sat Aug 16, 2025 11:30 am
 Post subject: loose gears, need help
PostPosted: Thu Nov 03, 2005 1:53 pm
ok so i dont have much knowledge about what things are called so i'll try to make this as easy as it is to understand...
the story: i was sittin at the lights, waiting for them to turn green, when they turned green i went to put it in 1st gear and "what the $^&%?" the gear stick went HEAPS to the left, so i couldnt get it in gear and once everyone went past me i reversed it back and parked on the side of the road (yes, thats right, i can get it into reverse easily)
so i pulled up my gear stick cover to take a look and that pipe thing (sorry) connected to the gear stick seem to be loose and it turns/rolls left when i push the gearstick over. so im just guessing that i can tighten this up pretty easily? but not sure? anyone know whats wrong, why it happened, and how i can fix it?
thanks alot
PostPosted: Thu Nov 03, 2005 2:28 pm
Rod change has two rods comming from the gearbox Or A Remote whic has a box from the box to the selector
It could be a number of things. But you will have to take the boot of anyway.
Remote it could just be the two screws ontop could be loose..Otherise pull the stick out let us know what you see
PostPosted: Thu Nov 03, 2005 2:49 pm
theres a picture, i tried takin a picture of when it turns but it just looked like this picture :P so thats it, and it turns when i try to put it in 1st gear (when i push left) so i have to be gentle. so u saying that it could just be 2 screws that i have to tighten or put back in?
PostPosted: Thu Nov 03, 2005 3:38 pm
To pull that apart, it has a bayonet fitting (just like a light bulb - twist anti-clockwise) and pull the cover off. When mine went west, the end of the gear lever has a little spherical ball attached, but mine was no longer attached. In your case though you may have to look underneath (its a rod change mechanism) and check that the little rubber "cotton reel" mounting bits have not broken.
Over 1,000,000Km, but now my retirement restoration project
PostPosted: Thu Nov 03, 2005 3:53 pm
mine does it too..
they just do it...
happens sometime when you stick it in reverse and push it the wrong way or twist it... just fling it round until it goes back in :)
PostPosted: Thu Nov 03, 2005 5:36 pm
Maybe not quite, the solid gear levers are OK but the two piece ones have a rubber insert between the lever and ball end. Thats where those ones expire and the stick at the top does not move the ball at the bottom.. where mine went.
PostPosted: Thu Nov 03, 2005 6:33 pm
OMG jim..is that you?..anyone else notice the eerie inclusion of correctly spelled words and *gasp* even grammar? :lol:
PostPosted: Thu Nov 03, 2005 11:39 pm
ok thanks, but just to make sure everyone is talkin about the same thing... its not the stick and the ball thing that im having a problem with. its the whole thing that its connected too... the big pipe which is turning. i'll have to get under it tomorrow and see if i can screw it to something :roll:
ive worked out that i can drive it fine if i be gentle, and turn the radio on... cause its makin a new noise :? better to pretend some things just arent there
PostPosted: Fri Nov 04, 2005 12:24 am
yes thats pretty impressive jim standards
but he spelt off and otherwise wrong and didnt include a semi colon after Remote
Inconspicuously Conspicuous
PostPosted: Fri Nov 04, 2005 6:38 am
hehe..Cheers Josh..I did Goodley 8)
While you down thier Stuvz, let us know whats happening with the rod's where they join the box and get some one to try and go throu the gears :wink:
PostPosted: Fri Nov 04, 2005 6:39 am
thier should be 4 screws holding a plate where the stick goes in also
PostPosted: Fri Nov 04, 2005 7:10 am
Hey stuvz, That is what my remote change was doing and as was said by circus_maximus, its most likely to be the little cotton reel mount underneath, pretty easy to replace.
Steve.
