It is currently Thu Aug 07, 2025 2:24 am
PostPosted: Fri Nov 04, 2005 3:51 pm
Somethings stuffed again....
Under power the engine vibrates and a loud popping or clanking sound comes from the engine. It also happens when I rev hard. As soon as I let go of the throttle it runs fine (this happens when driving or just revving). It also has hardly any power when driving..
Things I've checked:
- Spark plugs (all looked fine, nice brown colour but cleaned anyway)
- I checked the spark on each plug.. nice and big
- Timing
- Plug leads
- Twin carby's seem fine (I took them off and re-kitted and re-jetted them not too long back).
I havn't checked the compression yet, I'll do that though. Anyone got ideas on what it could be? What else I should checked?
PostPosted: Fri Nov 04, 2005 5:05 pm
does it sound like a tractor too? your compression test will probably come up with zippo on 2 and 3... head gasket
PostPosted: Fri Nov 04, 2005 6:11 pm
I just went and checked compression.. seems fine on 1 and 2 (round 170), but 3 and 4 were down round 50.. Could that be a head gasket?
and yep it's sounding like a tractor
PostPosted: Fri Nov 04, 2005 6:23 pm
I think your head gasket has goneAlex..sorry :?
PostPosted: Fri Nov 04, 2005 6:26 pm
Go check your radiator!!!! cant believe no one has suggested this yet.
Go check and if it's really bubbly and/or u can see traces of oil or white goo or anything sstrange its most definitely head gasket because the water from the jacket gets in with the oil.
PostPosted: Fri Nov 04, 2005 6:31 pm
Oh i did check the radiator.. seemed fine though.. Oh well looks like it's a head gasket.. Karcrafts not open on saturdays is it? Where else sells them that is open on weekends?
Thanks for your help guys!
PostPosted: Fri Nov 04, 2005 7:32 pm
:lol: :lol: :P Padstow Pirates or Brookevale Bandits!!!
if you are lucky, maybe MiniSuzi at Seven Hills
PostPosted: Fri Nov 04, 2005 7:50 pm
if it blows between the cylinders it won't have anything in the oil, and it'll sound like a tractor cos the compression is going from one cylinder to the other... and back with the exhaust - 1275's tend to go between the 2 & 3 AFAIK
PostPosted: Fri Nov 04, 2005 9:20 pm
Yep, 1275s go between 2 & 3 where gasket is thinnest. On 850-998-1098 they go between 1-2 or 3-4, again where gasket is thinnest.
Different gaskets... :wink:
PostPosted: Fri Nov 04, 2005 9:21 pm
if you need a hand or torqu rench mate just give me a yell!
