It is currently Wed Aug 13, 2025 6:58 pm
 Post subject: clutch problems
PostPosted: Thu Nov 10, 2005 9:09 pm
i have a 71 moke and am having nothing but trouble with the clutch. i have replaced all the parts but still can't get the adjustment right. i have bled the system and am confident that there is no air in the system. If i back off the adjustment then the slave cylinder won't push the rod out far enough. Is my clutch plate stuffed?
Mokin
PostPosted: Thu Nov 10, 2005 9:12 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
have you adjusted the little bolt on the clutch cover the pushes the arm out ??
makka
btw fill in yer location on yer profile helps us help you
PostPosted: Thu Nov 10, 2005 9:16 pm
yeah i have but according to all the manuals you should have a clearance between the top of the bolt and the arm. if I wind the bolt in to obtain the clearance the slave can't push the clutch out far enough.
Mokin
PostPosted: Thu Nov 10, 2005 9:18 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
noooooo you get some one to push the clutch in then adjust bolt and keep doing it till you get a good clutch BUT you dont want it sitting hard against the arm
makka
PostPosted: Thu Nov 10, 2005 9:22 pm
cheers for that. this is my first rebuild of a car (cheating a little using a Moke). i will give it a go this weekend. Just got the girl on the road last weekend after a few $$$ and lot of hours.
Mokin
PostPosted: Thu Nov 10, 2005 9:23 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
were ya from ????
makka
PostPosted: Thu Nov 10, 2005 9:24 pm
originally Vic but now living in Adelaide
Mokin
PostPosted: Thu Nov 10, 2005 9:26 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ok cool put it in ya profile there are lotsa adeladians on here and some of them are semi intelligent and may beable to help you ;)
makka
PostPosted: Thu Nov 10, 2005 9:50 pm
Adelaide...Hmmm. I might know someone who can help :roll:
Brickworx, Mini Tech, and Minisport are the most popular workshops. (Some will charge the earth, some will help out and just want a bottle of Vodka for their expertise... Brickworx Racing is my preferred, not that we're naming any names :wink: )
Okays, so with the clutch arm, pull it outwards with your hand, towards the inner wheelarch. This is the gap you will need to measure with the feeler gauges. Dont, like me at first, try to adjust with the clutch arm (and spring on top attatched) pushing against the lil' bolt. This will help you... Not at all.
Try for what the workshop manual suggests, but i find that a little extra here or there may be needed. You'll feel which way helps just by the feel of the pedal.
Good luck with it. :wink:
PostPosted: Fri Nov 11, 2005 8:12 am
There's two other things that I've seen done to get the clutch working better/correctly.
1. Get a bit of rod the same diameter as the push rod that comes out of the slave cylinder and weld a bit on to the end.
2. Take off the arm, heat it up and bend it - towards the slave cylinder.
The second one sounds a bit of a "Dodgy Brothers" but it does work.
Rod Image
PostPosted: Fri Nov 11, 2005 10:17 am
Both are 'dodgy brother's' if you need to do that, then you should be looking elsewhere...
Users browsing this forum: No registered users and 252 guests
