It is currently Fri Jul 18, 2025 11:22 am
PostPosted: Wed Nov 16, 2005 4:30 pm
So after succesfully derusting the clubbie grill I had a few months ago, I thought I'd give this grill a shot as the brown was really letting the rest of the outer bodys excellent condition down :(.
Pulled it of and began with the CLR and green scourer sponge thingies.
~45 mins later I've done one of the smaller stacks on the left end. I counted up the rest and realised I still had 60-70 little shelfs to do and the ones i've done are still not perfect. It seems derusting the edges of the little flats takes a lot more time then the middle no matter how hard I scrub.
It's slowly working and coming up a treat, but fiddle sticks me.. is there a quicker way to do this? I'm going to be on this for hours otherwise!
Shard
PostPosted: Wed Nov 16, 2005 9:01 pm
Shard wrote:
It's slowly working and coming up a treat, but **** me.. is there a quicker way to do this? I'm going to be on this for hours otherwise!
Shard
Rust removal by electrolysis- see http://antique-engines.com/electrol.asp
This does work- we set a rig up at work in a wheelie bin, with a bigass battery charger, for doing conveyor parts.
PostPosted: Thu Nov 17, 2005 8:55 am
A big damn bucket of molasses and water (I forget the ratio!) will do the trick too.
72 Clubman and a 75 Van.
PostPosted: Thu Nov 17, 2005 9:45 am
Electrolysis aye... hmm, I don't have jumper leads or a batt charger so that might come out a bit pricey :/.
Molasses hey... i'm guessing you just buy them from the supermarket?
Shard
PostPosted: Thu Nov 17, 2005 11:56 am
You could try the Mythbusters way..........aluminum foil and Coke :shock:
The ability to remove rust is ALWAYS a feature I look for in my beverage of choice :wink:
http://dsc.discovery.com/fansites/mythbusters/episode/episode_08.html
