It is currently Thu Aug 14, 2025 9:40 am
PostPosted: Thu Nov 17, 2005 11:48 pm
NAV-MAN
NAV sounds like he's got straight cut drop gears but the problem is it doesn't. It just got heaps louder like flicking a switch
At idle if i put my foot on the clutch it almost dissapears.
But under acceleration wow! sounds like a sccr box screaming it's head off. it's that bad i can't actually hear the engine anymore. If i back off and slow down using the engine it is just a bit louder than normal.
Tell me the bad news is it time for a re-build of my box? What sorta money am i looking at to get it fully re-built?
I might as well as it's my everyday car.
PostPosted: Fri Nov 18, 2005 2:18 am
my box did that too, rebuilt the box, and it still does it, but not nearly as much.
i think one of the main causes is the layshaft, the layshaft in my gbox was quite worn..
apart from that, i've heard maybe the drop gears, but i would like to know more too.
PostPosted: Fri Nov 18, 2005 9:02 am
i`d bet it`s chewed out the drop gear bearings (idler gear---the middle one)
it`s the most common cause for what you`ve described
rip it out now,,,don`t drive it,,,metal from there "WILL" totally root your entire engine
PostPosted: Fri Nov 18, 2005 9:27 am
Matts dead right ,don't drive it and get it out now, with luck you will only need the idler gear and new bearings
Jon
PostPosted: Fri Nov 18, 2005 10:58 am
NAV-MAN
Matt you interested in a re-build for me? Please Please PLEASE!!!
"Easy peasy" for you, payment in your choice of currency :wink: :lol:
I'd get NAV transported there if you take the job.
Would being difficult to get into first be a sign of this problem? NAV's always been a little hard to get into first.
I have no time anymore to do it myself and i need two cars on the road because i work outside public transport hours AND at the airport
PostPosted: Sat Nov 19, 2005 1:41 am
NAV-MAN
Anyone have a good condition rod change box woth pot joints they would like to part with? :?:
PM me with what you got and what you want for it.
Or reccomendations for getting it done by a mechanic.
I can't have NAV off the road for too long i miss driving him already :cry:
Users browsing this forum: Bing [Bot] and 254 guests
