It is currently Mon Jun 23, 2025 11:53 pm
 Post subject: Wirng Diagram GTI Swift
PostPosted: Mon Nov 21, 2005 7:45 pm
Can anyone help me, trying to track down a wiring diagram for an 87 GTI Swift (MK1).
Will settle for any model Swift though at the moment with the amount of luck that Im having. If anyone has one could you PM me your details and I'll give you a call in regards to possibly faxing me a copy. Any help much appreciated.
BTW its in a 64 roundie, just needs wiring, radiator & exhaust. (will be on the road by xmas hopefully)[/b]
PostPosted: Mon Nov 21, 2005 8:13 pm
If no one can help you here then try your local library for a swift manual.
Or you could try the swift sites.
Dan
PostPosted: Mon Nov 21, 2005 8:25 pm
www.redlinegti.com
It WILL have the answer you seek. PM a bloke by the name of puss_on_boost he is right into his MK1's and is a top guy.
PostPosted: Tue Nov 22, 2005 5:45 pm
Should be here:
http://www.redlinegti.com/forum/vth.148 ... manual.htm
or for mk1:
http://www.redlinegti.com/manuals/redli ... _MK1(SA413).Manual.zip
you need to type the whole link in for it to work....
mk 3
http://www.redlinegti.com/manuals/GTi.W ... anuals.zip
they are large files, so if you want just a particular page tell me and I can send it to you
PostPosted: Tue Nov 22, 2005 9:32 pm
Thanks for the help, tracked one down now.
PostPosted: Tue Nov 22, 2005 9:33 pm
Thanks
PostPosted: Tue Nov 22, 2005 9:40 pm
Thanks
