It is currently Sat Jul 19, 2025 5:54 am
 Post subject: Speedo
PostPosted: Sat Aug 28, 2004 5:22 pm
GRRRR. My speedo doesnt work. I have taken the 3 gauge cluster out and had a look behind... all seems well. The cable has a LOT of slack on it... it kept coming as much as i pulled it, i didnt want to pull it all out.
So one thinks taht the cable could be snapped.
How much is a new cable? and how hard is it to fit?
Will. :cry:
PostPosted: Sat Aug 28, 2004 6:25 pm
check that it hasnt come out of the other end first will
jack the car up and i tihnk it goes into the back of the gearbox (? maybe??)
play 3d car games for free
PostPosted: Sat Aug 28, 2004 6:56 pm
Yep i stuck my head under there.
Couldnt see much, but i called kevin @ minitech and he said its rare that they come out of the engine because they are screwed in.
Hmm bugger it.
PostPosted: Sat Aug 28, 2004 7:35 pm
Pull the inner cable right out from the top. The bottom end will have a square on it. Either this may have broken off or the square has a groove worn around it.
Best to replace the whole cable if so, but if not broken off it's easier to just put a new inner cable in.
Put a bit of grease on the inner cable, but leave the top 150mm or so dry so it doesn't get into the speedo head. :wink:
PostPosted: Sat Aug 28, 2004 7:36 pm
In all the books they say that it is really hard to put in a new cable with the engine in the car :shock:
PostPosted: Sat Aug 28, 2004 8:20 pm
No, it's pretty easy really. All depends how tight the bottom nut is. Worst case- take the bottom hose off. Or, put it up on a hoist. :wink:
And don't cross thread the nut when putting it on... :shock:
PostPosted: Sun Aug 29, 2004 8:23 am
I replaced Morris's Speedo cable last weekend, Pain :!: The old inner had rusted and broke. When replacing it I sprayed degreasier to the back of the engine and used a paint brush the get all the crud off the old bottom end of the cable.
Hope you have small hands, as its a tight fuit but can be done.
Make sure you dont make the same mistake as I did and not wash of the degreaser and burn my forearm replacing the cable.
But I was not able to just botom nut up Fkentight so I say its a couple of threads loose and thats the way it stays
PostPosted: Sun Aug 29, 2004 11:08 am
If you ride motor cycles, you'll know that some chain lubes such as Chain Wax are also excellent for cables too.
On a murder sickle, cables means bowden cables - don't know how they'd go on a speedo cable. No reason to think they'd be no good.
PostPosted: Sun Aug 29, 2004 8:26 pm
while were on the topic of speedo cables, im building a custom dash to house my late LS clubby ghauges in the middle, but speedo cable is way to long, is there anywhere i can get a shorter one ?
lookin for another clubby
