Hey boys,
So my handbrake... here is it's condition
1) Handle adjustment (inside the car) is at full, cannot adjust it anymore but it will only engage right at the very top.
2) Both right and left quadrants move freely (they do now
3) the brake adjust screws are set at highest level of adjustment (to push the brake shoes as close to the drums as possible. There is still heaps of space between shoe and drum
4) when I brake hard, it pulls up straight as a train so not sure if both rears are contacting at the same time or not... hard to tell
5) when I pull the hand brake, I only get the rear left side engaging
6) when i pull on the cable (not the handbrake but the cable on the rear suspension arm), the rear left side engages, when i try it on the right rear, it does not, although the mechanism inside the drum does move freely.
So do I need new brake pads on the right hand side rear? could it be wrong radius brake shoes?
Also I noticed that the hand brake actuator thingy inside the drum of the right rear wheel pushes the front shoe forward but does not push the back shoe backwards. Is it supposed to?
Thanks!
