It is currently Sat Jul 19, 2025 10:05 am
 Post subject: Smiths Tacho Cleaning?
PostPosted: Tue Aug 31, 2004 5:20 pm
Hi,
I was wondering if anyone knows how to pull a Smiths Tacho apart and clean the inside of the glass? As there seems to be some flaky paint inside of the one I have.. Or is it better to send it to someone to clean for me?
Any help greatly appreciated.
Thanks..
PostPosted: Tue Aug 31, 2004 6:04 pm
not sure... but i'm pretty sure my mum would dunk it in the sink....;)
PostPosted: Tue Aug 31, 2004 6:08 pm
Not sure myself Smith normal have tab's on the rim to hold it but I just checked mine also and I have same problem as you so I'm at a lose at the moment.
Have you worked out the wiring on the back. I'm guessing you have three connections on the back also
PostPosted: Tue Aug 31, 2004 6:11 pm
Yeah I have the same problem, there is a rim around the glass part of the guage that seems to be holding the back "cup" onto the front glass. I have no idea how you would loosen this metal rim to get at the insides...
If you find out, let me know!
Lillee - 1969 Morris Mini K
PostPosted: Tue Aug 31, 2004 6:24 pm
Hopfully Stay Tuned Chong
PostPosted: Tue Aug 31, 2004 6:25 pm
Cheers, then my $15 Tacho might work if I clean it up!
PostPosted: Tue Aug 31, 2004 6:39 pm
Surley you did not get a smiths Taco for $15.
I don't think i'll be following you around.
Where did you get the JD for Makka from :?:
PostPosted: Tue Aug 31, 2004 6:52 pm
lionel otto instruments up here in brisbane clean and reco old gauges but i don't know about the price...... as for down there i don't know
http://www.ottoinstruments.com.au/
PostPosted: Tue Aug 31, 2004 7:39 pm
Olympic Instruments (in Pymble) would do it but it will cost $$$.
Is it staked on like the speedo, or what?
Can't remember (last had one in `69...!) 8)
PostPosted: Tue Aug 31, 2004 8:19 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
south west instraments as well not sure on cost though
makka
PostPosted: Tue Aug 31, 2004 8:37 pm
Gaf, you were there dude! same guy I "stole" the oil cooler from. $15, 8000rpm smiths tacho, unknown condition.
It works via the 6 cyl plug but not the 4 cyl plug. I am sure it's a easy to fix thing once I figure out how to open the blardy thing! if not, off to a repairer or ... ebay :wink:
PostPosted: Tue Aug 31, 2004 9:11 pm
Dam that right. :twisted:
There are three plugs on the back but I'm at a loss which is which.
I thought I had it but will have to check it against my Special Multi Meter see if its correct (for got about That0 and see how it goes
PostPosted: Tue Aug 31, 2004 9:39 pm
When I was into pommie bikes, Dennis Quinlan was the guy to go to for instrument repairs. Can probably get his contact details if you want.
PostPosted: Wed Sep 01, 2004 10:32 am
Yeah there is a 12V and a 6V plug plus a (+) or ground terminal between them. The 12V looks like it is for V6? I have no idea...
Anyway I pulled her apart and you have to break the front chrome bevel thingy (mine is just black not chrome) to remove the glass and pop out the intruments.
I am going to test it today on my car again... I have a feeling I know what the little additional looped plug on the back is...
Stay tuned :)
PostPosted: Wed Sep 01, 2004 12:36 pm
OK Chaps, Calibration of the tacho is $22 from Olympic Instruments (Pymble). They will also look at what it's doing and why it aint going.
It seems that the 6V 12V has nothing to do with it :roll:
Well sounds like this chap is fair dinkum. Might need to give them a visit, worste of all, they aren't open saturdays :( . Lets see... $15 + $22 = $37... still good price for a tacho...
Testing comes first!
