It is currently Sun Aug 17, 2025 9:28 pm
 Post subject: Stepped Drums
PostPosted: Tue Dec 06, 2005 2:25 pm
Can anyone tell me what figure i would be looking at to get stepped brake drums for my clubby to get some 10" contessas onto it? :lol:
PostPosted: Tue Dec 06, 2005 2:44 pm
Brand new they are like $70 each or something, and it doesn't include the
longer wheel studs needed.
You could do considerably better if they are scond hand. Think I sold some for
like $15 or something round there.
PostPosted: Tue Dec 06, 2005 5:45 pm
$40-$80 each drum, depending where you get them, as always ring around the usual suppliers for the best deal
PostPosted: Tue Dec 06, 2005 6:25 pm
Depending on which Contessas you have, you may not need stepped drums. There's two different offsets.
The common type was intended for Minis with normal drums and fits without any flares required. If you fit this type with stepped drums the wheels stick out and flares are required. My van (on my website) has stepped drums and this type of Contessa. I swet my van up this way because I like the look with the flares filled out. :)
The other, less common type was fitted to Mini LS 998 with factory stepped drums. They will fit on a car with stepped drums without flares required but will foul the rear trailing arm on a Mini with normal drums.
Hope this helps!
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
Users browsing this forum: No registered users and 160 guests
