It is currently Sat Jul 26, 2025 5:55 pm
 Post subject: Cold gear crunching
PostPosted: Fri Dec 09, 2005 9:11 pm
Why is it that some gearboxes crunch that very first gear change from 1st to second (when cold only) ?
PostPosted: Fri Dec 09, 2005 9:19 pm
use the clutch :lol:
sorry
ook!
69 mini k
PostPosted: Fri Dec 09, 2005 9:25 pm
old ones or new ones?
i think it has something to do with the torque ratio in the lower gears creating larger forces on the synchros than the higher ratio changes. that seems to wear out the 2nd gear synchors and selectors more than other gears
its a theory :roll:
PostPosted: Fri Dec 09, 2005 9:39 pm
Oil is thicker when cold, lubricates baulk rings a bit too well sometimes- then they don't grip the taper on the gear.
Not helped in your case by that tight? idler gear... :cry:
PostPosted: Fri Dec 09, 2005 9:54 pm
i don;'t know why the crunch
mine does it from third to fourth gear....
PostPosted: Fri Dec 09, 2005 10:10 pm
mine got "fixed" when i put a new slave in and adjusted the clutch? :shock:
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Sat Dec 10, 2005 5:54 am
This can be a sign the nose bearing on the mainshaft has had it, the 4th gear synchro ring then gets worn out from supporting the shaft.
Baracade knows all about this.... :cry:
PostPosted: Sat Dec 10, 2005 7:05 am
it doesnt do it anymore if you extend the pin on the clutch arm, my mate is making adjustable ones because heaps of people have this problem.
Potato
PostPosted: Sat Dec 10, 2005 7:45 am
That's usually a sign that the clutch arm, or the bottom plunger, or pivot pin is worn out. :wink:
I just take the circlip out of the slave cylinder to achieve the same result.
Users browsing this forum: Bing [Bot] and 79 guests
