It is currently Sun Aug 10, 2025 7:08 pm
PostPosted: Wed Dec 14, 2005 7:56 am
How many times do people have to be told? This stuff is a POISONOUS and CARCOGENIC substance. Air respirators are NOT sufficient. You need total body covering as it is absorbed through the skin. The stuff we are using is illegal overseas because of the pollutants and personal danger to the operators. I have a mate who is a tech teacher in spray painting and he point blank refuses to use it. It is madness to even contemplate using it at home outside a controlled environment and if caught your pocket will be lighter by a whole lot I would think. Unfortunately this is not one of those jobs for the amateur and should be left to the professionals.
Chris
Everything I like is either
PostPosted: Wed Dec 14, 2005 8:02 am
For some reason the topic has reverted back to normal 2pac. what JAM was after info on is the iso free stuff. this ou can buy from repco and the likes. Anybody have more info?
Aaron
PostPosted: Wed Dec 14, 2005 8:19 am
Aaron
it is ausmini.. when does it ever stay on topic :?
PostPosted: Wed Dec 14, 2005 8:15 pm
:roll:
PostPosted: Thu Dec 15, 2005 6:37 am
So is there a 2K (base coat or clear) that an enthusiastic amateur could successfully use at home, or is it out of the question? It would have to be non-toxic, go off at room temperature (10 degrees Celcius in NZ...) and not require anything too expensive to spray.
PostPosted: Thu Dec 15, 2005 8:46 am
ok so, yes there is an iso-free 2-pak clearcoat available. Most retail paint places are only allowed to sell this type due to the nature of isocyanates which are found in normal 2-pak. Also, iso-free 2-pak clear can be used over a metallic acrylic base coat, but it must be iso-free otherwise the clearcoat will peel off.
EDIT: no baking required either.
Users browsing this forum: No registered users and 183 guests
