It is currently Fri Jun 27, 2025 4:32 pm
 Post subject: silver/grey colour info
PostPosted: Fri Dec 23, 2005 4:21 pm
OK all i was there at the mini dyno day (for all you who were there) was wondering if any one remembers what colours Graham russels LS is (std colour i think) and His little van was a very similar colour.
also does any one know what std colours came out on the Aussie clubman panel vans?
Mine is off to the panel shop and i suppose i should really look at deciding what colour i would like it painted.
any help would be great.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Fri Dec 23, 2005 4:26 pm
Was it "Hi Ho Silver " ?
J
PostPosted: Fri Dec 23, 2005 4:31 pm
hi ho is the only one ive heard of
PostPosted: Fri Dec 23, 2005 4:32 pm
dunno was it?
Im asking not guessing.lol
How is your turbo running now? a guy over here has asked me to build him one alsmost the same spec as your but im reluctant due to unknown terratory?
any build advice with what you have done with your black one now?
PostPosted: Fri Dec 23, 2005 4:39 pm
Finially got my A/F meter wired up, got to attach it to the sniffer yet, but once that is done, I'll get it sorted for a base-line tune.... then off to the Dyno for a ful tune...
Running real nice now, temps are a lot more stable, and predictable, but still pinging over 10Psi and 1/2 throttle ....
Water injection hooked up and functional, just sorting the jetting now (currently too large.. )
Once all that is sorted, should be running sweet and well over 85@wheels.....
The next step is to take it over 100@wheels ....
Re-bore, dished custom pistons, more Chamber work, intercooling and a more agressive cam profile.... over 130@wheels should be available if i use Dry-Ice intercooling.. but more about that another time, hey ?
J
PostPosted: Fri Dec 23, 2005 4:55 pm
Jai,
Yes Graham's 1275LS is Hi-Ho Silver. The van colour, I'm not sure.
PostPosted: Fri Dec 23, 2005 4:56 pm
Definitely Hi Ho Silver.
The other LS colour is Nugget Gold, which is like Poeee's and a couple of others on here also.
KB
PostPosted: Fri Dec 23, 2005 5:40 pm
ok tonto about the hi ho silver.
would like to know the color of the van im sure heard it was a holden colour.
Jim, sounds great what cam are you running now?
I have a guy over here with a 998 turbo motor with methonol injection at 8lb boost and will run upto 13lb boost and recons 200HP at wheels but i think he is dreaming a bit but he also says he is having problems with clutch slip.
PostPosted: Fri Dec 23, 2005 6:21 pm
RE-13T a GR "one-off" ... suits the Small-Block Turbo very nicely at the moment...
I'm also getting Clutch slip (Blue Diaphragm - Cooper "S") so I'm guessing over 100@Flywheel at the moment.... when my DR Mini ST Clutch and backing plate go in, I'll stick a Grey Diaphragm in i think......
J
PostPosted: Fri Dec 23, 2005 6:24 pm
J
James are you coming on the run on 27th? If so I'll stick your lightened S backplate in the boot... :wink:
PostPosted: Fri Dec 23, 2005 6:25 pm
Slow-Po
I've looked through my photos and can't find one of the van, however you are right it was a very different colour to the yummy LS. (is that putt putt next to it?!)
PostPosted: Fri Dec 23, 2005 6:39 pm
disregard last post...
I'm OFF on Tuesday, so I might just come along.. depends on the Weather.... but still, if i'm NOT there, could you Pelase give it to Max ?
I wouldnt mind ripping the beast out and giving it a good clean-up anway ......
J
PostPosted: Fri Dec 23, 2005 7:03 pm
Will do. Don't forget the light flywheel and backplate both now will need a balance... and you need 3 washers each .200" thick to go under the flywheel straps. 8)
PostPosted: Fri Dec 23, 2005 7:55 pm
Hi Ho silver in that pic looks really good
Anytime I have seen one it looks really crap, that's the colour my LS is supposed to be, the one I can't work out if I can afford to save from the crusher.
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Fri Dec 23, 2005 8:03 pm
so who has a picture of the van?
doesnt chong look like a thief in the LS?
jim ill chat to you in another thread about stuff like that.
but a blue is too light even for my car, i use a button clutch and a orange in my road car and a double grey and button in my race car and dont let people tell you they are either on or off its not true, you can slip them a fraction and a bit of judder now and again but other that one leg bigger than the other i have no clutch slip problems.
