It is currently Fri Jul 25, 2025 6:19 pm
PostPosted: Sat Dec 24, 2005 3:27 pm
ok so i have the old oil filter off and the new one ready to go on...BUT :roll:
the bolts that come out of the block that the normal oil filter slides on to are obviously not needed for my new screw on oil filter as the new one had screw in bolts- how do i get these out??
i have tightened up the nut and tried turning it that way but no success
i have no idea as usual :oops: can someone shed some light on this for me??
PostPosted: Sat Dec 24, 2005 3:31 pm
ok,,,get 2x nuts,,,do them both up a fair way & then tighten them both together on the stud, as in do one up while trying to undo the one under it, they will both lock together, Know what i mean???
then with your trusty spanner, start to undo the one underneath & the stud will undo, once it`s loose & easilly able to be undone by hand then simply unlock both nuts from eachother & spin them off the stud,,,do the same for the 2nd stud
easy-peasy
PostPosted: Sat Dec 24, 2005 3:34 pm
yeah :wink:
TheMiniMan wrote:
easy-peasy
:shock: we will see :lol:
PostPosted: Sat Dec 24, 2005 3:48 pm
Note the gasket onto block is totally different, the old style one will not fit the spin-on housing.
Easy to make one from gasket material, if you don't have the proper one handy. :wink:
PostPosted: Sat Dec 24, 2005 4:53 pm
yeah i was sold the right gasket! infact i got the hole set up including the feeder pipe and filter for $60 which is fairly cheap i believe...now more money to spend on fixing other things :lol:
got them out easy- thanks for the directions Ready you were right :D
new oil filter is on and isnt leaking at all- so now my mini is on the road i believe
i recommend this mod to anyone it saves all the trouble and only takes about half an hour to do8)
thanks again
PostPosted: Sat Dec 24, 2005 4:55 pm
$60 !!!
I was selling the Whole unit, including the pipe for about $10 at the swapmeets .....
Oh well, Live and learn .....
But yea, was one of the first mods i did to my car .... had enough of those cartridge thingos on my old Minx......
J
PostPosted: Sun Dec 25, 2005 1:12 am
you`re most welcome Matt, merry christmas then ey? :-)
& JimBob, you nutso you,,,they`ve been like $45 for years,,,,Pppft 10 bucks, dam i would have bought all of em off you had i known :-)
PostPosted: Sun Dec 25, 2005 5:19 am
Haha... that's why you're rich Matt, and James, me and many others here are poor... :)
Merry Xmas!
PostPosted: Sun Dec 25, 2005 5:22 am
If you want your bearings to last a heap longer - block off the oil filter blow-off relief valve in teh spin on filter heads... they relase at some ludicrously low poundage, feeding your crank bearings a steady stream of unfileterd oil... Did this in Mini Mag - and mat be on my site too (www.calverst.com). And for those wanting to loose oil leaks for ever and eliminate non-filtered oil issue, I do a billet machined job - on my site again. KC.
PostPosted: Sun Dec 25, 2005 5:28 am
Keith, do you recommend silver soldering the ball in there, or is better to pull the whole valve seat out and replace it with a plug?
PostPosted: Sun Dec 25, 2005 7:15 am
screw on oil filters (new) range from $60-$90 here in adelaide :!:
ohwell atleast my car goes now and merry christmas to everyone :wink: .
PostPosted: Sun Dec 25, 2005 10:00 am
Rich you say kev? Rich??? well maybe rich with "LOVE" for this wonderfull little car & all the people surrounding/involved with them
but wealthy $$$ wise, i`m well short there, i`m scraping the arse out of my boardys just to make ends meet , it`s lucky (or good management) that i have a big crew of guys with me when i travel around Aust with my racing as they basically pay for the trips & i just drive the truck :-)
well ok i also cook & clean & manage a whole heap of wankers who don`t really give a crap about what stuff they`re breaking or leaving lying around on the ground & have no concideration for anyone elses gear,,,but at least they pay the fuel bill :-)
PostPosted: Sun Dec 25, 2005 10:52 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey matt be nice i'm a sometime's pit crew person for mal rose only time i stuffed up was when he told me to get the fuel churn out of the truck and i said the red one he said yeah ........ so i used it and it was full of gunk oop's blocked fuel filter
also had to pull the tank apart and get all the crap out of the tank good head spins
makka
PostPosted: Sun Dec 25, 2005 10:58 am
hee hee,,,yeah i`m with ya,,,i crew for Bruce Ayers Litre sprint car speedway team (i`m crew chief now days :-) ) & we run that lovely blinding brain killing, can`t see it burning, lovely smelling, methanol. YUMMY TELL YOUR MUMMY!!!!!!! :-)
been on both sides of the fence
wish i had a few of "ME" as crew for me, then i`d only have myself to blame if things went pear shaped :-) but then i`d probly have some sort of "bi=polar" disorder, probly allready do,,,brought about by all that fuel sniffing. :-)
no i don`t,,,yes i do,,,no i don`t,,,yes i do :-)
ok that`s enough Matt,,,no it`s not, yes it is, no it`s-------
PostPosted: Sun Dec 25, 2005 11:03 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
mmmmmmm methonol love the smell of it after it has been burnt
makka
Users browsing this forum: Bing [Bot] and 70 guests
