It is currently Mon Jul 21, 2025 12:06 pm
 Post subject: while i have no mini...
PostPosted: Sun Dec 25, 2005 11:15 pm
im going to need a crap box to run me to work and stuff.. im talking something really crappy, a cheap ass pov car to get me from a to b...
anyone here want to sell me their shitbox that runs for not much?
i saw this beast for sale and they want $350 for it,
Toyota Corolla 1980 rear wheel drive red sedan 1.8L 4 speed, 250000kms, rego expires 14/1/2006, little maintenance required in past 12 mths
or then for another hundred i could go for something more similar to the old car, hahah
Leyland Marina Morris, Neat and Tidy - Drives Well.
ah funny, funny stuff :shock:
PostPosted: Mon Dec 26, 2005 12:50 am
:? YUCK.
Mate.... nothing compares.
Even a cooner mini (LS, nudge nudge) shits all over those two. :wink:
 Post subject: Go the corolla
PostPosted: Mon Dec 26, 2005 5:18 am
Go the Corolla, I had a mate who use to rally them, they are tough tinnys are will sweve the purpose. When your finished you can use the rockers and shaft to setup on your mini to give you a high ration rocker set.
Hope its a manual though the Auto was really bad.
PostPosted: Mon Dec 26, 2005 5:52 am
Buy a corona as your get to work car. They last forever.
DO IT ONCE, DO IT RIGHT
PostPosted: Mon Dec 26, 2005 5:54 am
Yeah the rockers will fit, but the shaft won't.. and if it did all the oil holes are wrong for a Mini head.
I bronze bush the Toyo rockers to 9/16", machine them to .625" wide and use a thick wall Mini shaft. And modified Mini rocker posts- the shaft hole moved back 4.2mm. :wink:
Fair bit of work, but worth it!
PostPosted: Mon Dec 26, 2005 6:17 am
Doc
after all that work you have achieved?
Nigel
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Mon Dec 26, 2005 7:40 am
Klubman wrote:
Doc
Nigel
Rocker ratio with these is 1.46:1 rather than the 1.24 or so for stocko rockers. :wink:
= More valve lift, works well with 1275 and up.
PostPosted: Mon Dec 26, 2005 8:55 am
to move the hole in the rocker post by 4.2 do you fill in the hole first then put in the new hole?
Sorry this is getting away fron the original topic but The Doc started it drifting off
Is this particular mod worthy of a place in the How to section?
75 Clubman
PostPosted: Mon Dec 26, 2005 9:29 am
willy wrote:
:? YUCK.
yea no crap mate but i only want to spend a fww hundred towards a downie car, just so i can get to work and stuff :cry:
i know its gonna be hell embarrasing but yea, gotta do something :(
PostPosted: Mon Dec 26, 2005 10:58 am
Go the 'rolla - they were the only cars that my sisters owned that I never had to work on!
PostPosted: Mon Dec 26, 2005 11:03 am
whinja ninja
whinja ninja
Go the KE55 (Corolla).
Poeee drove one of these (his mother bought it new) and reliability is ace! If you get one with no rust (rust killed these things, make Mini's look good), then you've got a winner.
Oh... they are RWD :wink: :wink:
I don't know my name anymore.
PostPosted: Mon Dec 26, 2005 11:37 am
OK, yeah this is drifting off topic a bit I guess..
There are 3 ways I know of:
1. Turn the rocker posts around, drill the rocker stud holes out to 10mm to clear the head studs.
I don't recommend this- there is little metal there to tighten the head nuts onto with the posts reversed.
OR-
2. Braze steel plugs into the rocker shaft holes, then redrill the holes accurately 4.2mm back (easy if you have a mill, like I do).
Works OK, I've done a couple of sets this way now. You cannot MIG weld these posts- they are sintered material and full of oil, but they do braze OK.
OR-
3. Get some 20x50mm flat steel bar, and mill up a new set of rocker posts.
Also works OK, did 5 sets like this but it's a heap more work.
I think this Toyota rocker mod is beyond most Mini owners, unless they have machining experience, a mill and a lathe. But if you want to try, do a search in the Mini Mods forum for `hi lift rockers' thread, or PM me. :wink:
PostPosted: Mon Dec 26, 2005 12:11 pm
those corollas have cool windows :wink: center post drops down
mate had one as first car pretty unkillable
ook!
69 mini k
Users browsing this forum: slacko and 84 guests
