68matic wrote:
i played around with the timing in my dizzy
now my engine is EXTREMELY quiet.
the only thing that tells you the car is on, when you are in it,
is the vibration of the steering column under your hands
and the little taps of the rockers.
sometimes when you put your foot down, it stutters twice and revs up normally
it has no trouble goin up hills
steve (and mikey) and bob told me "your engines retarded"
with a straight face
they said i could turn the car on, tap the dizzy this way
get rid of the popping in the exhaust
or tap it the other way whilst the car is on
and just listen for just the right sound coming out of the exhaust
is it so straight forward? (he did it to all of his cars and they're fine)
Short answer is NO,as there are too many variables involved in the build of various engines.
You can get it close, listening to it at idle, (IF the dizzy has the right advance curve and is not worn, etc) but what really matters for power production is that the timing advance is right at 4000 rpm and above.
`Power timing' involves advancing the dizzy a degree or two at a time and checking for improvement while accelerating in 4th gear. If the motor starts to ping at low speed, or it starts to get rough, you have gone too far- retard it a bit until it stops pinging.
I set mine at
above 4000 rpm with a timing light, to a mark on the crank pulley that I have found gives the best (`seat of pants') power. With my particular engine (with strange bits and mods in it and no vacuum advance) this is just over 40 degrees...
I could care less what the advance is at idle.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
