It is currently Thu Aug 14, 2025 11:08 am
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
 Post subject: Door Cards
PostPosted: Sat Dec 31, 2005 7:36 am
Has anyone retrimmed there own door cards? If so can you post some pics as I am wanting to retrim mine and want to get some ideas.
Madarsemini
DO IT ONCE, DO IT RIGHT
PostPosted: Sat Dec 31, 2005 8:18 am
Hey madarsemini, I used a product called Amerind MDF Board, which can be bought from Bunnings to make some new door cards. I used the 3mm size as it can bend quite easy to fit onto the doors.
The material I used was bought from Spotlight and we fitted it ourselves, using a spray on glue and a small staple gun..
If you click on my link to Clubman LS, you can find pics of the before and after in the Interior Improvements section ..
PostPosted: Sat Dec 31, 2005 8:37 am
Looks pretty cool cheers
PostPosted: Sat Dec 31, 2005 8:39 am
does this MDF self-destruct if it gets wet? I was going to use some thin polycarbonate sheet... 8)
PostPosted: Sat Dec 31, 2005 11:16 am
I have used the Amerind MDF Board on other things than on the Mini Doc and it seems to hold up very well. I'd say it would handle water a lot better that cardboard, masonite or 3 ply...
PostPosted: Sat Dec 31, 2005 11:52 am
when mdf gets wet it swells a bit, but it still does the job well
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Dec 31, 2005 11:58 am
mate there easy as to make and unlike a lot of things you can actually make them look professionally done with time and patience
get some board i think i just used ply and coated it in lacka and what not to seal then trace your old ones on to it cut it with jig saw or hand saw
mark out you screw holes etc
i then bought some spray glue from a craft store i think and some padding its like a sheet of pillow type stuff and glued that onto the board let dry then cut your material i used thick vinal and stretched as i put on
glue it to the cotton padding with the spray then tack nail the back to the board so it stays tight and doesnt sag
mine look great better then some pro ones ive seen and as i said easy to do but a little time consuming
PostPosted: Fri Jan 13, 2006 5:16 pm
what size ply did you end up using? was it 3ply? Also roughly how much did you have to buy?
With great power comes great responsibility. It also comes with one kick ass ride.
PostPosted: Fri Jan 13, 2006 5:30 pm
I reused the vinyl off my original door trims and made myself some new mdf backing panels and just restuck them on the new ones. Straight as now, no more wobbly door trims and still have the original trim. All good.
Wouldnt be too hard to wrap other materials or even customize them though. good luck with it, show us your results
PostPosted: Fri Jan 13, 2006 9:42 pm
how did you end up going?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Jan 13, 2006 10:39 pm
hey, Ive found the trick to waterprooofing mdf and many other materials is to paint it with bondcrete, awesom crap... like wrapping it in glad wrap :lol:
th other trik is to put some new plastic between the door and the new interior skin, this stops splashs etc, neva have a problem again!! 8)
-Cam :lol:
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Sat Jan 14, 2006 11:01 pm
hey im not a noob anymore! YAY! I'm going to try the mdf with a waterproof agent, then try some shmick custom door cards, could take a while due to work but when its finished........EL SWEETO?
PostPosted: Sun Jan 15, 2006 4:44 pm
where does the water proof agent go?
PostPosted: Sun Jan 15, 2006 4:45 pm
Around the farken muffler :roll:
PostPosted: Sun Jan 15, 2006 4:47 pm
i seee...?
im new to cars so dont blame me for my stupidity.
Users browsing this forum: No registered users and 295 guests
