It is currently Tue Jul 22, 2025 12:43 pm
 Post subject: is this stuffed?
PostPosted: Mon Jan 02, 2006 9:31 pm
Okay, pulled this out this arvo. All of them are like it.
Can I clean it up or do I need newies?
Cheers! Nunny
off to NT I go
PostPosted: Mon Jan 02, 2006 9:42 pm
Looks shagged in several respects.
Smallbore valves are cheap. :D
Get a new set, and fit 8 new guides- they are shagged too... :lol:
PostPosted: Mon Jan 02, 2006 9:45 pm
i got a hole head here (very good condition) if ya just wanna throw one back on?
or i have heaps of good condition valves here to..
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Mon Jan 02, 2006 9:53 pm
I am rebuilding an engine for the first time with a couple of books as my only guide and I have no idea what I am doing!
Anyway, it's all a learning experience. So good Dr, are the guides the round disc like bits that the collets sit in?
And thankyou for the offer Clubman, I am rebuilding a spare so no need for a quick head replacement. I will let you know bout the valves though..........
off to NT I go
PostPosted: Mon Jan 02, 2006 9:58 pm
would this motor be for a racing series :roll:
i just took mine apart and rebuilding it for that :wink:
PostPosted: Mon Jan 02, 2006 10:11 pm
nah, we got an engine off Mr. Brickworx for the mini1000, just gonna put some new rings in that one and see how it goes......
This one is in pieces and not running and with no experience I am not confident of doing a great job. That is why we needed an engine that ran for mini1000 :wink:
Coincidently though, both engines are stamped 9YATAH. Is that spooky or are there heaps of these going around?
off to NT I go
PostPosted: Tue Jan 03, 2006 5:31 pm
iam not too sure but i think that engine no was on all morris's not to sure but :?
PostPosted: Tue Jan 03, 2006 6:11 pm
No, the guides are the round bushes in the head that the valves go into.
If the valves stems are worn as yours appear to be, the guides will be worn too.
Good practice is to fit new guides, whenever you fit new valves... :wink:
PostPosted: Tue Jan 03, 2006 11:50 pm
thankyou very much doc. I read a thread about the type of head I have which is ecam 4004 and you mentioned that the 12g202 is much better. All I am after is a reliable engine, not necessarily the fastest. With that in mind is it worth spending the time and money on this one, or source a 12g202?
thankyou for your help and advice thus far
cheers, Nunny
off to NT I go
 Post subject: PB
PostPosted: Tue Jan 03, 2006 11:58 pm
Dr...have you tried Phosphur Bronze guides :?: (not a trick question)
 Post subject: Re: PB
PostPosted: Wed Jan 04, 2006 5:40 am
Yes Mick, I run them in Ha-Ha, which has plain S/S race valves (incompatible with iron guides).
No, they don't last any better than iron ones do.
And valve stem seals should only go on the inlets with these, as the ex ones need some lube.
Cast iron guides are less trouble, if using standard valves.
BTW in UK they seem to call these guides STEEL, but they are not so.
I've found you need to ream the bronze ones ALWAYS after fitting, as they shrink- but the iron ones don't seem to change size.
Some S/S valves these days have chromed stems, so can run in stock cast iron guides.
Many racers use iron guides with K-liners fitted, this gives the best of both worlds but costs more $$.. of course!! :lol:
