It is currently Fri Jul 18, 2025 2:05 pm
 Post subject: Oil feed to turbo
PostPosted: Wed Jan 11, 2006 8:18 pm
Now that i am making a log for the exhaust manifold i have thought about removing the factory oil relocator altogether and simply fitting the standard oil filter.
I will pick up the oil feed for the turbo by installing a T-piece where the oil pressure switch is relocated.
Any comments or issues that people can see with this?
Dan
 Post subject: Re: Oil feed to turbo
PostPosted: Wed Jan 11, 2006 8:29 pm
Dan
We must have different models as mine doesn't have a factory oil relocator. Is there enough room in the round nose to fit the oil filter in the standard location?
JC
PostPosted: Wed Jan 11, 2006 8:54 pm
The factory relocator is really an offset piece fitted where the oil filter would go on an 4efe. All 4efte models have this due to the turbo position.
I think the standard oil filter will fit with out a drama.
Dan
PostPosted: Thu Jan 12, 2006 8:27 am
Yeah doesn't it simply sit pretty much flat against the engine?
PostPosted: Thu Jan 12, 2006 9:55 pm
T-piece on the pressure switch is working fine on mine......that's how most people do it....
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Thu Jan 12, 2006 10:19 pm
Dan
I spied what you where talking about tonight. Looked at it and realised "oh, it's offset" must a been what the dude was on about", the "relocator".
