It is currently Mon Jul 21, 2025 11:41 am
 Post subject: Cold carby...huh?
PostPosted: Thu Jan 12, 2006 7:53 am
This morning I got to work and decided to pop the hoody and adjust the idle a tad.
I noticed that one of my twin HS2's was covered in condensation and was noticeably COLD to touch. The other carb was warm to touch, as you would expect.
How on earth do you get a COLD carby, when everything else is so hot in the engine bay? :?
Website: www.justanothermini.com
PostPosted: Thu Jan 12, 2006 7:57 am
there twins..... They are posesed by the devil i dell you :cry:
PostPosted: Thu Jan 12, 2006 7:58 am
well they run a LOT better than my HIF did :P
PostPosted: Thu Jan 12, 2006 8:07 am
thats cause you did not rebuilt it eh :lol:
PostPosted: Thu Jan 12, 2006 8:11 am
actually my friend...I DID :wink:....I just didn't get another needle for it :lol:
PostPosted: Thu Jan 12, 2006 8:13 am
Gave up to easy.. and the old log of Jims would not help :P
PostPosted: Thu Jan 12, 2006 8:28 am
I ported the log.... :lol:
I was doing this over xmas / new year and EVERYWHERE was closed. Even rang GR, but there was no answer. MIDEL's never got back to me TWICE :x I needed the car running so went back to the trusty twins :wink:
I have been googling and it seems that carb condensation is OK....but something must be out if ONE is doing it, and not the other!!! :shock:
PostPosted: Thu Jan 12, 2006 8:35 am
Not sure about it either , is there any reason for one to be getting more heat than the other , broken heat shield or slight exhaust leak onto it ? Possibly the cold carb is doing 80% or so of the work and is colder due to greater air flow , have you checked if they are balanced right at higher rev's (assuming you've done all the normal checks and setting up) as well as lower revs ? DOn't know what else but I'd keep trying to figure it out in case there's a blockage or something that causes a mixture lean out on one side ....
PostPosted: Thu Jan 12, 2006 8:37 am
aaahhhh....there is a point. With air filters removed I hear greater suction from the 'cold' carb.
Something must be up with the warm one.
PostPosted: Thu Jan 12, 2006 8:45 am
waste of time. :shock: just get better manifold.. 8)
PostPosted: Thu Jan 12, 2006 8:47 am
I've had both SU's freeze-up,when driving the Mini on the Alphine Way :roll:
PostPosted: Thu Jan 12, 2006 10:01 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ive heard of this it is called carb iceing can cause the throtle to stay wide open
makka
PostPosted: Thu Jan 12, 2006 12:20 pm
 Post subject: Re: Cold carby...huh?
PostPosted: Thu Jan 12, 2006 4:36 pm
I have mentioned a few times on here about carby ice but most people ignore it as something that only happens in freezing Goulburn. 8)
How was the weather this morning? cool and moist? Yes, I thought so!
Prime conditions for carby ice.
It sounds like your carbys are out of sync at idle and one carby is doing squat at the other is flowing twice the air that it should. If you re-set the idle (just open the screw on the lazy carb and back off the screw on the cold one) it should be fine. If they were both working properly they would both have been cool but not cold.
Carby ice can come in a few forms, if your throttle shafts are worn it will suck air past the bushes and the moisture in the air will freeze and jam the throttle :shock:
The other way is a build up of ice inside the carby blocking the flow and cause a bad misfire.
PostPosted: Thu Jan 12, 2006 5:01 pm
Resident Haemorrhoid
Gold Paint :?:
maybe JAM is to 8) for its own good :wink:
mtsmini wrote:
Tombo wrote:
Users browsing this forum: Steam and 84 guests
