It is currently Tue Aug 19, 2025 2:07 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Jan 16, 2006 6:40 am
just be carefull with the belt kit you have as the bottom pully (crank end) is very tight on the crank. I heard from a very reliable source that they made all these pullies then realised they made a bit of a fopar and realised the key way on every crank is at a different height.
DO NOT KNOCK ON THE PULLY as it will strech the outside of the pulley and you will leak oil from day one.
the pulley must slide on nicely onto the crank.
unlike mine which was a little tight so i tapped it on thinking it was the anodizing had made it tighter but NO it was the key was higher up than to be expected and deformed the bottom pulley causing a major oil leak and now i have to change the belt in a few weeks time when it take the motor out.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Mon Jan 16, 2006 6:45 am
Yes, it's important to make them a nice slide on fit. If you start using levers or drifts on them, you will bruise the teeth and it will chew the belt.
Same goes for the cam pulley... :wink:
PostPosted: Mon Jan 16, 2006 8:24 am
yeah.. so whats the options if they are tight? :?
PostPosted: Mon Jan 16, 2006 8:27 am
Polish inside the pulley and the outside of crank, with fine wet/dry paper. Pay attention to the corners of the keyways, and the key fit. :wink:
PostPosted: Mon Jan 16, 2006 8:32 am
cool. looks like a BBQ and beer day at my house then :lol:
PostPosted: Mon Jan 16, 2006 8:50 am
or send me the bd kit, i got crank already...:P
PostPosted: Mon Jan 16, 2006 9:01 am
Good thinking. you got my hole motor there now. :lol:
but not much point putting it all on before i paint the block again.. :(
PostPosted: Mon Jan 16, 2006 9:09 am
Watch out Cody!!!
That's the same gasket set I used on JAM's 1115 motor. The gasket for clutch housing to block is too thin, and made my idler gear end fload too little......
For my rebuild I bought an ACL set, and that particular gasket was .010" thicker!
Website: www.justanothermini.com
PostPosted: Mon Jan 16, 2006 9:16 am
Thanks Anton... Kev has them all atm.. so he can look see. :wink:
PostPosted: Mon Jan 16, 2006 9:24 am
Stop hogging Kev, Cody :P
PostPosted: Mon Jan 16, 2006 9:30 am
He love it.. I keep his beer frige stocked :lol:
PostPosted: Mon Jan 16, 2006 10:02 am
Well if I knew all it took was beer.....
I have a couple of slabs here with Kev's name on it :lol:
hehe, hole motor indeed.
PostPosted: Mon Jan 16, 2006 7:34 pm
Pistons here today 8)
PostPosted: Mon Jan 16, 2006 7:35 pm
Mmmmmmmmmm... Hypatec 73.0mm. 8)
I need a set, for the 1412 stroker motor... :P
Last edited by drmini in aust on Mon Jan 16, 2006 7:37 pm, edited 1 time in total.
