It is currently Mon Jul 21, 2025 5:35 pm
 Post subject: 1100's motors?
PostPosted: Mon Jan 16, 2006 8:33 pm
Hey guys, (and girl's sorry) i'm just looking up engine numbers and the like, and i see that according to :
http://www.minis.com.au/
Ive got a 1100's motor in my van. Now i know i have heard something about them being good things to have.
Is that because they are an 1100 bore in a 1275 block?
and therefore are more likely to give a few extra rebuilds?
Or is there some other reason?
number is : 12y/Ta/h8591
One Lill-Red 1100
A project morris van
One rusty assed delux shell
and a clubby van
PostPosted: Mon Jan 16, 2006 8:37 pm
1275 without the tappet plates on the back. Came out in the morris 1100.
Others will fill you in more on this.
76 1275 Leyland S
PostPosted: Mon Jan 16, 2006 8:41 pm
The whole 1100 thing is a misnomer
The 1100S actually had a 1275 instead of the 1098
It is a standard 1275 motor, which is a good thing :)
PostPosted: Mon Jan 16, 2006 8:59 pm
yeah theyre' nothing special
mos't 1100's have had the'ir engine's stol'-ded for minis'
PostPosted: Mon Jan 16, 2006 9:07 pm
i was waiting for that^^
ook!
69 mini k
PostPosted: Mon Jan 16, 2006 9:53 pm
i beleive some MOggie 1100S's (<-- is that ok, will?) had cooper S spec internals...
i think the doc or morris 1100 (even simon k) will have this info
PostPosted: Mon Jan 16, 2006 10:06 pm
Early ones had a small journal, crossdrilled crank with Cooper S rods, never seen one factory fitted with an S EN40B crank though.
PostPosted: Mon Jan 16, 2006 10:32 pm
ok.. four out of five aint bad... ;)
PostPosted: Tue Jan 17, 2006 1:38 pm
hey Benmcf1 did you recently buy that mini??
i recon i saw it advertised sumwhere, or a very similar 1
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Jan 17, 2006 3:41 pm
Ok thanks all.
I guess there are some misconseptions floating around re 1100's motors.
But i think the conclusion is..... On a motor that has already been recond and transplanted into another mini, then left is a shed for 7 years till the rings rust to the barrel's. There aint nothing special about it :)
Gee i hope there is still room for a rebore.
mad-mk1.
I bought it about 8 months ago.. So it may be the one you saw. Was in on consighnment at Moris mania then mini sport thats all i know. I got it from the latter.
One Lill-Red 1100
and a clubby van
PostPosted: Tue Jan 17, 2006 9:42 pm
Plenty of scope for rebores on these- can get pistons in +.020", 040, 060, 094 (73.0mm) and .115 (73.5mm).
Used to be able to get 74mm too but they've gone , like the dodo. :lol:
