skssgn wrote:
hey supercharged 850 - I'm curious about your ignition, and the induction length you've got on the carb side of the blower - was it a matter of the only place you could put the carb, or did you make it that long on purpose? please share some of your personal learnings
The carb couldnt fit any closer in my situation... If i was to change to a flatter carby (eg weber), i could have it much closer to the blower, but the SU is a very upright carb - i'd need a 4 inch lump in the bonnet if it was any closer
Not what i want to do...
I'm also having a few belt alignment/bracket problems at the moment, SO bad that i'm going to redesign the whole setup AGAIN (for the 4th time)
..... I'm looking at moving the carb so it faces forwards, alongside the drivers side headlight, behind the bonnet...
Ignition at the moment is a modified Lucas dizzy - the bob weights are lengthened to limit the total advance... but I've got a Pulsar electronic dizzy here that is getting modified to suit the SC....
