It is currently Sun Jul 27, 2025 8:56 am
Post new topic Reply to topic  [ 140 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10  Next
PostPosted: Thu Jan 12, 2006 8:13 pm
on a 71 GT, were the A panel badges 'Brittish Leyland' (see pic) or 'Leyland Australia' ?
Website: www.justanothermini.com
PostPosted: Thu Jan 12, 2006 9:26 pm
Is there any GT's around we can go measure up the stripes Anton?
Would be cool to reproduce some!
PostPosted: Thu Jan 12, 2006 9:36 pm
hmmmm...I know of one nearby. LOTS of curves and stuff in those stripes. How do you measure that?
PostPosted: Fri Jan 13, 2006 5:04 am
There are a few signwriters over here that have taken patterns from original GT stripes and can reproduce them. Let me know if you have any issues getting them there as I am just about to order a set.
PostPosted: Fri Jan 13, 2006 7:48 am
Hi,
Kiwi1275
How much is the complete Clubman GT stripe set? Are they a exact replica of the Australian Clubman GT stripes? How much to send to Australia?
Thanks
PostPosted: Fri Jan 13, 2006 7:50 am
old trick of the trades :wink: Get a piece of chalk and paper then rub the pattern. Dont tell anyone i told you Anton, this is an old signwriters secret
PostPosted: Sat Jan 14, 2006 7:34 am
i have posted a few times on this topic. The pattern for the stripes the signwriter has is probably the one I made up for my own car (I made vinyls whilst living in the UK). I sent it to a signwriter here in exchange for a new set. The file was made up of a pattern drawing taken off a factory set that were not put on the car. I think they are as close as possible to the original, but without being able to see an original set I can only assume. The foil GT badges for the back are no problem either. Brushed aluminium vinyl with the red GT inked on during manufatcure. I have had a couple made up here and they are excellent - all that is needed is a picture of one and they can print and cut. Chopchop - are you in the trade then? The hard part is digitising a pattern so a cutter will read the file. There is software that can do this, but I made mine using measurements.
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Sat Jan 14, 2006 7:36 am
My original 72 Clubman has 'British Leyland' A panel badges. I figure the 71 GT had them as well.
PostPosted: Sat Jan 14, 2006 9:21 am
yeah i'm a sign writer by trade. I could probably make them off a photo and a few different measurements.
PostPosted: Mon Jan 16, 2006 6:12 pm
GT WHEEL COLOUR ?
Does anyone know the RIGHT colour for original GT rims? I have a feeling it ISN'T Silver Birch.....
PostPosted: Mon Jan 16, 2006 7:40 pm
Anton,
There are at least 2 maybe 3 different colours all called Silver Birch.
The first dates back to 64/65 and is colour No 06968.
The second one dates from 71/72 and is colour 13260
The third is called wheel silver met and is colour code 11452 and dates from 71/72 and I think this could be the colour on Mini S wheels etc. Does the GT use the same colour? From what I can remember (KRAFT disease?) I think the GT wheels were painted in a lighter silver colour than the original darker grey silver birch. So most likely it is the Wheel Silver metallic that is the correct colour.
Colour codes are from Dulux Autocolour books I have.
Regards
RonR
PostPosted: Tue Jan 17, 2006 7:42 am
Cheers Ron!!
I had some Silver Birch mixed up about 12 months ago. The paint mixers labeled the can 'Leyland Silver Birch' ...... I will have to check out the colour number...I have a feeling it's the 2nd one you have mentioned.
Is there a colour number for the 'Wheel Silver Metallic'?
PostPosted: Tue Jan 17, 2006 11:44 am
:oops:
Anton,
I've added the code for the wheel silver metallic to the previous reply.
Also the code for the first Silver Birch was wrong. I've corrected that and also found that it was a Nissan colour from around 68/69.
Sorry about that. Must have suffered from brain fade or the dreaded KRAFT disease. Well just a little bit.
Hope it's of some help.
Regards
RonR
PostPosted: Tue Jan 17, 2006 2:02 pm
As shown in this pic (and many other GT pics I have seen), below the sill seams is painted BLACK.
Is this correct for GT's ONLY, or were ALL Clubman's of that period (71/72) painted black below the sill seams?
PostPosted: Wed Jan 18, 2006 3:22 am
My original 72 Camino clubby 1100 is camino below the sill seam.
