It is currently Fri Jul 18, 2025 7:09 pm
 Post subject: engine mounts
PostPosted: Wed Jan 18, 2006 9:46 pm
can i use the stock mini engine mounts?
they are nice and compact and I could easily make them work.
they are shaped like an S.
gti motor.
btw I have bent all my pipes up for the subframe.... just can't seem to cut the front off the mini frame. ( not physically but mentally ) why cut up a perfectally good subframe....... ah its going to happen
 Post subject: mounts
PostPosted: Wed Jan 18, 2006 10:00 pm
You could but there's better choices
Std GTI Mk2, Barina gearbox mount
KC-KE Ford Laser for rear mount (Kenpro 8121)
Mazda 808 72-78 for front mount (Kenpro 8135)
This setup works well
Blue
Keep shiny side up
PostPosted: Wed Jan 18, 2006 10:07 pm
are these mounts able to be used with a mk2 suzuki gti
PostPosted: Wed Jan 18, 2006 10:31 pm
yeah I know but they cost money.....
the mini ones are there and they are new!!
PostPosted: Wed Jan 18, 2006 10:37 pm
The mounts will fit both Mk1 & Mk2 but not the Mk1 gearbox
Do the job properly & don't use "mini" mounts
Blue
Keep shiny side up
PostPosted: Wed Jan 18, 2006 10:49 pm
what is wrong with mini mounts?
I think that the mazda 808 mount has a few short comings actually
PostPosted: Wed Jan 18, 2006 11:20 pm
this is what the mini mount is like....
PostPosted: Wed Jan 18, 2006 11:32 pm
The mounts I quoted are tried and tested
When you said "mini" mount I assumed normal BMC A series mount
Blue
Keep shiny side up
PostPosted: Thu Jan 19, 2006 5:59 am
Baracade's Starlet conversion has NO engine mounts..... it's mounted solid!! :shock: :?
PostPosted: Thu Jan 19, 2006 9:04 am
can you not use the suzuki mounts?? mine uses the 3 normal toyota mounts :D
1974 Moke - 998cc
PostPosted: Thu Jan 19, 2006 9:35 am
try to use factory engine mounts for the suzuki, mounts like that mazda when worn can break and the engine will drop, the angle of these are important when fitted and are only really good for rwd conversions. modern mounts will transfer less noise and are much stronger
57 Morris minor
88 Rover Mini
PostPosted: Thu Jan 19, 2006 12:39 pm
the ones that I have a freaking huge and thats why I like the mini engine mounts..
Only used on the engine part, and not the gearbox.
PostPosted: Thu Jan 19, 2006 1:56 pm
yes they are pretty big I searched through the wreckers next door to my workshop to find suitable ones that are smaller. does the suzuki use one at the front and back of the motor and one on the gearbox (like my sirion) if so the mini ones might be ok
57 Morris minor
88 Rover Mini
 Post subject: Mounts
PostPosted: Thu Jan 19, 2006 10:01 pm
Why don't you listen?
The mounts I have used are the best & easiest way to mount the Suzi motor
The Laser mount goes on the rear of the block & the Mazda one goes above
where the aircon mount attatches, how can it break when it is sandwiched
between two plates with the weight of the engine sitting on it
Engine mounting plates must be constructed so that if for any reason the
mount itself fails the engine cannot fall out of the car, this is an engineering
requirement
As for BMC mounts they give no rotational or sideways stability & can be only used
in the same plane & angle as the original A series engine is mounted
It is not worth the time & effort to try & reinvent the wheel
If you want to see how it is done PM & I will Email you some photos
Blue
Keep shiny side up
 Post subject: Re: Mounts
PostPosted: Fri Jan 20, 2006 12:07 pm
I have seen Blumin's conversion(s) and they are the best. As he said, why try and reinvent the wheel?
Chris
Everything I like is either
