It is currently Sat Jul 19, 2025 12:38 am
 Post subject: metrinch
PostPosted: Thu Jan 19, 2006 9:27 am
why would you want a normal spanner/socket set when you could have metrinch? are there any instances where you cant use a metrinch spanner? it would seem to be better in all ways...it works on rounded nuts too...i just cant think why a normal set would be preferably over a metrinch set...i love my new metrinch spanner...only got 1 but i am seriously thinking of investing in a full socket set...metrinch converts unite!
Bling me up Scotty!
PostPosted: Thu Jan 19, 2006 9:43 am
What size metrinch do you have? It may help me remove the pesky 12/14mm nut that is currently giving me the irates. Damn support bracket for the cat converter is getting in the way. I may even let you come around to check out Striped, so long as you bring it with.
JC
PostPosted: Thu Jan 19, 2006 9:48 am
http://www.rswww.com.tw/electronic-comp ... socke.html
the one i've got is a 12mm one...that rounded nut on the aircon unit came straight off...no if's...no but's...
Bling me up Scotty!
PostPosted: Thu Jan 19, 2006 9:49 am
Whatever floats your boat.
I find it's a sh*tload easier & cheaper to weld a nut on if I round off a bolt head etc.
PostPosted: Thu Jan 19, 2006 9:51 am
sure...but i am just talking normal spanner vs metrinch...are there any instances where a normal one is BETTER than the equivalent metrinch one?
Bling me up Scotty!
PostPosted: Thu Jan 19, 2006 11:28 am
pricey ?
PostPosted: Thu Jan 19, 2006 11:46 am
marcsvenson wrote:
pricey ?
harder to get ahold of...but not really much difference in the price...got a quote for a 30pc socket set in metrinch for $120...from...tool city i think it was...
Bling me up Scotty!
PostPosted: Thu Jan 19, 2006 12:38 pm
well they are a pina when you have a confined space to do up a bolt/nut. you have to turn it that much more before it bites. when you only can move the thing a flat at a time you can't use a metrinch spanner. I would imagine that fitting these engines in the small engine bays plus all the other stuff you would have alot of cramped spaces.
PostPosted: Thu Jan 19, 2006 1:10 pm
inazuma_x wrote:
the one i've got is a 12mm one......
Well well well. Sounds like just the one I need. It may be sufficient to allow access to the garage. You can check out Andy's thinga-me-jig whilst there too.
PostPosted: Thu Jan 19, 2006 1:14 pm
hehe...my secret key :P
when we talking? this weekend i am off to inskip with some mates for a camp out n piss up...anything after that's fine :P
Bling me up Scotty!
PostPosted: Thu Jan 19, 2006 1:38 pm
Come around tonight if the scoot scoot allows.
PostPosted: Fri Jan 20, 2006 8:23 am
soz man it was PISSING down over my way...not good scooter riding weather :P
Bling me up Scotty!
PostPosted: Fri Jan 20, 2006 12:15 pm
they are a great emergency kit i guess. check out your Bunnings stores, cuz if they have any left, they are a deleted line, so you would get a great deal on them. give me a peripheral drive socket anyday. the metrinch shows its inefficiency in its name. if it is to fit the 2 met and imp sizes, one is always going to be slacker than the other, and not work as well.
keep a few "standard" sizes in them for those rounded off peices of crap bolts that make you wanna burn your car... stick with a proven method mate, you'll thank yourself in the long run.
http://www.minisport.com.au
the guys there are dead set champions
PostPosted: Fri Jan 20, 2006 12:19 pm
well i've got a standard socket set and a standard spanner set...they have served me well for many a year...no plan to get rid of them at this stage...but i was pretty pleased with how well the metrinch spanner worked getting the rounded nut off...and couldnt see a huge difference in performance when using it on non-rounded nuts/bolts either...still wondering if i should invest in a full set of metrinch...although 4efte nuts are either 10mm, 12mm, 14mm or 17mm...so it doesnt really matter i guess...could just get those 4 for emergencies...
Bling me up Scotty!
PostPosted: Fri Jan 20, 2006 5:49 pm
I have a set of their spanners and would not change them for anything else 8) I hit them with hammers I stand on them ( I am 100+kg) none have bent cracked or even lost chrome. I have had them for about 3 or 4 years.
Yes they won't swing aswell in tight spots but you just use the next size down and use the flats in the front of them like a normal spanner.
these are the ones I have
67' Matic
73' S
