It is currently Thu Aug 07, 2025 3:41 pm
 Post subject: steering rack oil??
PostPosted: Thu Jan 19, 2006 11:10 am
Hi giuys, the gregory's manual tells me to replace my steering rack oil (i drained it while replacing the boots).
where do i get SAE 90 EP oil from?
PostPosted: Thu Jan 19, 2006 11:13 am
SAE90 is gear oil...same as what goes in a Holden diff for example. Repco should carry that.
BTW...I filled mine with grease. My theory was less liquid to drip onto my garage floor :P
Website: www.justanothermini.com
PostPosted: Thu Jan 19, 2006 12:38 pm
Go to a reliable suspension/steering shop and beg, borrow or buy some proper rack grease. Just because your car was built in the past you don't have to condemn it to live there for ever..
Ian
PostPosted: Thu Jan 19, 2006 1:39 pm
I filled mine with grease after it was overhauled.
As JAM IT said no oil leaks.
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Thu Jan 19, 2006 4:02 pm
OK..Thanks!!
Grease it is!!!
PostPosted: Thu Jan 19, 2006 7:07 pm
Ian
Ian,
The guys who built these Oz racks at Cam Gears in Sydney, I used to work with. They say OIL was better lube than grease, they went to using grease purely to reduce oil leaks. They recommend topping up with OIL, even on a grease packed rack.
Problem with grease is, it dries with age, the rack cuts a track thru it, then no lube.:(
90/140 is the oil grade if you can still get it.
PostPosted: Fri Jan 20, 2006 1:14 pm
Hi Kev,
Most (all??) modern cars use grease. There are special formulations intended purely for steering components. I was persuaded to use it when I installed my Mk II rack in the early 90s and last time I looked (around 2002) it was still pretty gooey.
As long as the boots are intact i can't see any volotile components escaping..and once the boots go, the dirt wil get in anyway. Although with grease the rack will probably survive longer than if the oil escapes.
Cheers, Ian
PostPosted: Fri Jan 20, 2006 1:20 pm
OK I'll buy that, the grease they used in the distant past here was nothing special which is why I like oil. :lol:
BTW my 1970 rack is still in car, original, not sloppy yet- had 1 boot replaced in 36 years and 140,000 mlies approx. And regular 90EP oil top-ups... :wink:
