It is currently Wed Jul 23, 2025 9:52 am
 Post subject: Whether Seals
PostPosted: Thu Jan 19, 2006 3:03 pm
Is there anywhere i can buy a set of seals for my mini, both door seals,both windscrean seals,back window seals,front sliding window seals, i need them preety quick cause i dont want water getting into my rust free mini :( also how much will these cost.
PostPosted: Thu Jan 19, 2006 3:06 pm
If you can't wait till tomorrow to have some delivered from Karcraft, go down to clark rubber and have a look at some of the sections they keep in stock.
Simply find the closest stuff, and buy it by the meter.
PostPosted: Thu Jan 19, 2006 3:11 pm
aight thanks
this karcraft place does it have a site so i can check out everything thhey have?
PostPosted: Thu Jan 19, 2006 3:14 pm
http://www.karcraft.com.au/home.php
although you are probably better ringing them up.
They also have a printed catalog with prices which is alot more helpful than the online one :wink: it's free so make sure you ask for one :wink:
Roads need more corners
PostPosted: Thu Jan 19, 2006 3:18 pm
Karcraft does have a site (www.Karcraft.com.au ????) but it doesn't list everything they have.
I have just had the windscreen rubbers renewed and for that you are much better to go for the right rubbers from Karcraft with the right profiled sealing strips. If you can get appropriate door seal rubbers etc from Clarke then good but get the correct windscreen rubbers. The one piece (uncut) rubber totally seals and lasts for many years.
