It is currently Fri Aug 01, 2025 1:58 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 19, 2006 10:06 pm
Are you taking 998 still then??
<edit> ah OK just saw the other thread...
:oops:
S rods used in a 998 had a Miglia piston, which is NLA.
The A+ 998 had press fit rods but the pins were much smaller than S-
Last edited by drmini in aust on Thu Jan 19, 2006 10:09 pm, edited 1 time in total.
PostPosted: Thu Jan 19, 2006 10:09 pm
Yea, Still talking smallie now..... (Check the Big Decision Thread...)
Just want a "Bullet Proof" bottom end.... Probably also go for a centre strap and a few other little twiddles to keep it alive.....
I've got a set of "S" rods hidden away that coupld potentially be used.. but if they are no good for a smallie, I'll put them back in the bank safe box .... :roll:
What other options are there.... Hemi Rods ? - maybe Starfire ? - Bike ?
I'm open to anything, you know me !!
J
PostPosted: Thu Jan 19, 2006 10:10 pm
Nothing wrong with standard rods, the bolts are suss though. I'd run Genuine Unbrako cap screws as GR does.
Or get some A+ rods if you want press fit pins.
<edit> If running a 1098 crank, at HIGH revs, I'd watch the piston circlips... they are a weak point. PTFE buttons?
PostPosted: Thu Jan 19, 2006 10:13 pm
Cool, Gosford Engineering should be able to get them for me, yes ?
Any idea of Thread / Length to ask for ? also, they would need a plain shank, yes ?
O might just take an original rod-bolt down and get them to match it... probably be easier !
No clearance problems with the extra length of the bolt-head ? - it would add about 1/2 to the crank throw, wouldnt it ?
J
PostPosted: Thu Jan 19, 2006 10:18 pm
No problem with the bolt heads from what I've seen. Take a bolt as sample.
Beware PLATED bolts, they are bad news...
If made in PRC, look elsewhere.
