It is currently Mon Aug 18, 2025 11:13 am
Post new topic Reply to topic  [ 377 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 26  Next
PostPosted: Sat Sep 04, 2004 9:36 pm
Hey Kevin,
What does the rotor button in the Nissan dizzy supposed to look like? Mine was an ordinary rectangular shape usual type but when I was at Supercrap today I looked it up out of curiosity thinking I might get a new one and the list points to a round one :shock:
David L
PostPosted: Sat Sep 04, 2004 10:07 pm
Stock rotor is a balanced, ie double-ended one. :wink:
Round would be OK, if it fits....
PostPosted: Mon Sep 13, 2004 10:32 pm
For anyone in Adelaide still looking for a D4R85 there is one at the northern U Pullit at Elizabeth.The Pulsar is hidden amongst the Holdens instead of the other Nissans which is probably why its still on there. $45-$50 will probably get you the Dizzy and coil.
PostPosted: Tue Sep 14, 2004 12:30 am
pfff - elizabeth??? there's a bigger "u-pull-it" out north - its the westfield shopping centre carpark - leave your car there and some bastard will knock it off.... :lol:
PostPosted: Tue Sep 14, 2004 9:02 am
why do you need the coil as well as the dizzy?
PostPosted: Tue Sep 14, 2004 9:56 am
different resistance - 4 & 8 ohm from memory. the car won't run well (at all) if it has the wrong coil. This is probably why people describe the electronic ignition has having a fatter/better spark.
Ps I remembered that I had left the coil out of the things to keep off your freebie Honda. You do need to keep the honda coil for the same reason for when you put a Honda ignition. I would assume it would be the same with the nissan also.
KB
PostPosted: Tue Sep 14, 2004 10:10 am
Cheers Kevin.
The Honda arrives at my place this week. Do you have more info on converting the dizzy from it?
I still can't believe I am getting this thing for nix.
PostPosted: Tue Sep 14, 2004 2:26 pm
JAM,
Not really. I bought one already converted which is now on my car, I also have an umodified one put aside as a spare.
Apparantly the Oz Mini magazine (mini Magic?) did do an article on it in one of their (4?) issues, so maybe someone may have that and could copy it for you.
There is more machining work to be done than with the Nissan as you have to dissassemble it, hacksaw off the base at a certain point and make up a collar to suit the mini clamp. The guy I bought mine off machined some aluminium for this purpose and used araldite to attach to the base - sounds dodgy but looks and works ok.
Graham Russell would probably be able to help as I think the guy did the machining there.
You are welcome to come around and have a look at my car for ideas. I can guide you on the wiring up of it as I did that part myself. I think Ausmini4u has also done this conversion so may have some details.
Kevin.
PostPosted: Tue Sep 14, 2004 7:00 pm
KB
Dunno about the Honda one, but the Nissan has a 1.5 ohm coil. That's why it gives fat sparks compared to a normal 12V 3 ohm one. (1.5 ohm coils are usually used in points ignition systems with a ballast resistor, which knocks the applied voltage back to 6 or 7V). But in this case it gets the full 12V applied.. :P
I'm running .040" gaps, no problem at all. I've had it up to 8000 rpm. The Pertronix ignitor I had in before with a Bosch GT40 (3 ohm) coil wouldn't fire them over .037" gap.
PostPosted: Tue Sep 14, 2004 10:33 pm
Hey JAM,
I;ve got the mini mag with the Honda dizzy conversion. PM me if you want me to post you a photocopy.
Dave
PostPosted: Tue Sep 14, 2004 10:49 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i have a dizzy already converted here for sale
makka
PostPosted: Wed Sep 15, 2004 8:31 am
MadMin wrote:
Hey JAM,
Dave
Dave, PM sent. Much appreciated
Makka, is yours finished or half done?
PostPosted: Wed Sep 15, 2004 12:46 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
finished i think the guy who did it lost the ignighter then i got a petronox
makka
PostPosted: Wed Sep 15, 2004 2:13 pm
Anyone doing the Honda Dizzy conversion and hasn't got the electronic module I have a couple you are welcome to.
David L
PostPosted: Wed Sep 15, 2004 9:49 pm
whats that?
