It is currently Mon Aug 04, 2025 10:26 pm
 Post subject: HELP!!!!!!
PostPosted: Sun Jan 22, 2006 7:34 pm
i need help wiring my starter solenoid.
here a pic
please HELP!!! not sure where every thing goes.
Rikki
p.s sorry bout the size took it with my phone
PostPosted: Sun Jan 22, 2006 7:42 pm
Brown wires to the battery side of the solenoid
Ignition switch will go to one of the terminals on the side. Try one then the other.
PostPosted: Sun Jan 22, 2006 8:57 pm
thanks Morris 1100 i tried that but the car wont turn over.
PostPosted: Sun Jan 22, 2006 9:10 pm
Is there power when you turn the key on? (Do the warning lights on the dash come on?)
Does the solenoid click when you turn the key?
Try running a jump wire from the battery side of the solenoid and touch it to the small terminals one at a time. It should make the solenoid click when you get the right one.
PostPosted: Thu Jan 26, 2006 8:18 am
Hey, Thanks Morris 1000, i hooked them up (found the right ones) but now when i turn the key to start it starts but the starter motor keeps going. Any ideas??
Rikki
PostPosted: Thu Jan 26, 2006 9:21 am
Rikki
check the 4 large screw terminals for one that is only +12v when the ignition switch is in position 3 (cranking). Thats the starter terminal.
Users browsing this forum: No registered users and 127 guests
