It is currently Sat Jul 19, 2025 4:48 pm
PostPosted: Tue Sep 14, 2004 8:15 pm
Anton
yeh mum labelled the can, i fixed it up: DUC MINI HYDRO FLUID
next time i reckon ive got the inclination to take a wiff and a sip before pouring anything into anything
i soaked up all the frothy stuff from the float chamber (dam lucky the fluid couldnt be sucked up into the carby through to the engine)
and held a container under the incoming hose to catch all the fluid while running the engine with good petrol in the float chamber
if you copy n paste some of these links
you might find some pics of a mc hydro pump
made by John Goudie
http://www.angelfire.com/mech/ducho/hydropump2.JPG
http://www.angelfire.com/mech/ducho/hydropump1.JPG
doc is yours similar?
and i drove the moke around tonight, canley vale, cabramatta being next door
but i got home fine
Inconspicuously Conspicuous
PostPosted: Tue Sep 14, 2004 8:49 pm
sorry, I can't see the pics - it just says 'image hosted by angelfire' they must have something tricky to stop direct image links - would hate for people to use their service without being bombarded by advertising.....
PostPosted: Tue Sep 14, 2004 9:15 pm
copy n paste :wink:
PostPosted: Tue Sep 14, 2004 9:38 pm
OK here 2 pics of my Mini MC hydro pump. Mounted on a upturned Fiat 124 pedal box.. :wink:
Told you not pretty! :lol:
PostPosted: Tue Sep 14, 2004 9:48 pm
Wow, that looks great compared to mine!
My pump is made out of a Morris 1100 pedal box and uses the pedal and master cylinder. I got a high pressure hose from the railway.
The mini tin tank is a bit small and you need to top it up every couple of pumps.
Dr, does yours have a non return valve or do you rely on the schrader valve as the non return?
PostPosted: Tue Sep 14, 2004 9:54 pm
I use the Schrader valve as non- return. I bleed the hose thru before I screw it on.
Fitting is even more agricultural than the setup- I took a brass valve cap, drilled it thru, turned the OD parallel in the lathe, then soft-soldered it into a brass fitting. Seal is the rubber ring from said valve cap.
Hoses are a pair of Mini ones joined with a bit of brake line- to turn the outer hose and fitting, I loosen the flare nut on the pipe in the middle, screw it on the schrader valve then tighten the flare nut. Bit messy but it works OK. :wink:
PostPosted: Tue Sep 14, 2004 10:02 pm
That is the same way mine is set up! I used a valve extension (used on the inside wheel of trucks) and we silver soldered a fitting onto it.
I did make a non return valve out of a morris rear brake pressure limiting valve when I first set it up but I deleted it when I made the good hose.
PostPosted: Wed Sep 15, 2004 8:17 am
made in true old school fitter and turner style ey Kev.... :lol:
PostPosted: Wed Sep 15, 2004 11:06 am
fantastic :D
now forgive a dumb question - what is a schraeder valve ? I've heard of them, but have no idea what it is or does
PostPosted: Wed Sep 15, 2004 12:32 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
sk i would imagian it is thye thing at the end of the pipe :roll:
i thought it was the old type of valve thing that was on the old foot pumps but then again i have no idea i'm just clutching at straw
makka
PostPosted: Wed Sep 15, 2004 4:33 pm
A Schraeder valve is a normal tyre valve...
They were also used on hydros to hold the fluid in. :wink:
Makka, U need something better than a foot pump's `air chuck' to connect- the fluid is around 300psi... :shock:
PostPosted: Wed Sep 15, 2004 4:35 pm
Anton, I WAS in a hurry- and used what was handy... :lol:
PostPosted: Wed Sep 15, 2004 6:52 pm
Re: the hydro depressurisation scenario - the BMC handbook says you can still drive the car at speeds of up to 30mph on a completely depressurised system... Id like to be driving that car... The next sentence advises the unlucky driver to proceed immediately to the nearest BMC dealer...
Ha.. ill just drop into Heads BMC Carnegie then hey..
Why would you want a thicker fluid? Mine feels too stiff as it is - maybe becuase its a fairly recent repump.. I only ask because my mate has a Morry 1100S which floats on fluid - and i mean floats - its a really nice ride.. OK, my K handles better.. but I love the ride on that car. Im guessing the longer wheelbase may contribute to that??
Comments anyone?
PostPosted: Wed Sep 15, 2004 7:35 pm
yes I've driven mine flat `to the nearest dealer..' when I got there he charged me heaps for 10 minutes work!
So, I went home and built my hydro pump... :lol:
I hate to admit it- but hydro was a much nicer ride on the longer wheelbase M1100 and A1800, than in the Mini..!
Only point in stiffening the ride a lot is competition. I believe `some' works cars had restrictor valves in the lines for this purpose.
On a few G13B Suzuki GTI conversions I've seen, they separated the displacers F/R and ran 4 separate circuits. I would think this would stiffen the ride a lot- any SuziMini owners like to comment??
PostPosted: Wed Sep 15, 2004 9:59 pm
yeh when i was flat i rocked up to my 'dearest kneeler'
and boy did she blow me up right, on her knees
didnt charge much
and didnt even have my mini with me :shock:
sorry i just HAD to say that
gimme a beating now :oops:
