It is currently Wed Aug 13, 2025 3:09 am
 Post subject: Rear Side Window Seal
PostPosted: Tue Jan 24, 2006 3:42 pm
Just a question , i bought a set of new rear side window seals and they seem to be to big???? do these seals come in different sizes...they are the 1 piece joined seal -no ends... Please Explain.............to fit 1970 mini.
:D :) :D
Cheers Monster Mini
PostPosted: Tue Jan 24, 2006 3:56 pm
Always a chance they could be for a later mini , once the pom's went to the internal door hinges their mini's used taller and wider rear windscreens and taller side rear window's , can you check them against a later model mini (anything with internal door hinges ) ? Other than that no ideas , where did you get them from , a local dealer or did you import yourself ?
PostPosted: Tue Jan 24, 2006 4:10 pm
I picked them up from Karcraft, i spoke to the guy there and he said they shoud fit ...but of course they dont...should i cut them... What do you think ,also will they leak if there cut...
Cheers Monster MIni :D :) :D
PostPosted: Tue Jan 24, 2006 4:14 pm
Don't cut them , good chance they'll leak , ring the place you got them from and check in case they have a batch that is marked wrong or something . A mate and I drove 4 hours to a Brisbane MG specialist to pick up a windscreen for his MGA , got hom and found it wouldn't fit , 3" too wide . The whole shipment had been cut to an oversized template as somebody stuffed up the zoom factor on the computer , basically there can be problems with things , just check it's the right part number and if they have had any others with problems . How much bigger than the window opening is it ?
PostPosted: Tue Jan 24, 2006 4:33 pm
the ones on the car at the moment are cut...i fitted one of the new ones on three sides went on and on the fourth side I got about half of it on ,so theres about 5-10 cm extra.
cheers Monster Mini
 Post subject: Window seal
PostPosted: Tue Jan 24, 2006 10:19 pm
Sounds like a pommy one to me
Blue
Keep shiny side up
PostPosted: Wed Jan 25, 2006 2:42 am
I've just replaced these on my wife's mini. Although it is a pom Mk3 with the 'big' windows, I thought that the one piece rubbers were made too big. Same as you - 3 sides on and the 4th seeming way too big. In desparation, I went back to side 1 and adjusted it so I was really squashing it into the corners and compressing it along the sides as much as possible. This worked and the rubber fitted!! It also seems to have a fantastic tight seal now and NO water comes in.
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Wed Jan 25, 2006 8:08 am
Thanks for that will try that as soon as i can ...
:D :) :D
Cheers monster Mini
PostPosted: Wed Jan 25, 2006 9:12 am
I fitted some too not long ago and just had to push them into the corners more and try and squeeze it all in.
Hopefully it all works out!
PostPosted: Wed Jan 25, 2006 9:20 am
I think who ever manufacturers them may allow for some shrinkage as well so when they are first fitted they may seem too big :idea:
Roads need more corners
Users browsing this forum: No registered users and 247 guests
