It is currently Mon Aug 18, 2025 2:33 am
 Post subject: cracked piston!!
PostPosted: Fri Jan 27, 2006 4:07 pm
heyyyaaaa
Well, i think ive discovered why the number 2 cylinder keeps fouling plugs.
I shined a torch down through the sparky hole and can see a crack along the piston.
engine still goes strong..think ill just run it in dead and then upgrade to somthing larger.
any tips? or stories like mine??
1978 Leyland clubman S.
PostPosted: Fri Jan 27, 2006 4:53 pm
Sounds like someone isn't letting their engine warm up :roll:
PostPosted: Fri Jan 27, 2006 4:57 pm
nah, ive had the mini for about 5 months now, and its had the problem the whole time.
so id say the previous owner may have been the cause.
PostPosted: Fri Jan 27, 2006 7:02 pm
I part seized a piston at Wakefield Pk track last Feb, drove it home 150 miles... :lol:
Bore still ok. Piston is pretty S/H...... :shock:
PostPosted: Fri Jan 27, 2006 9:43 pm
this happpened to me, except i musta drove it till it broke off :shock: , first thoughts was a blown head gasket, until i pulled the head off. Only to find that i was missing a chunk from my piston head, and the sore deep groves inside the cyclinder. So bad it was too deep to rebore, my advice it to pull it out and do something with it before the block becomes unusable :x
Image Image
PostPosted: Fri Jan 27, 2006 9:49 pm
i cant afford to do anything with it at the moment..its only 998, and when im able to upgrade i was thinkin 1275.
it sux tho.
PostPosted: Fri Jan 27, 2006 11:04 pm
Well if the piston falls off the conrod the engine will be toast along with the gearbox and probably everything else too.
If you can't afford it now, it will sooner or later go bang and it could be that nothing will be salvageable from the 998 :shock:
PostPosted: Sat Jan 28, 2006 12:41 am
yeah, why do people do that to minis, when something breaks they just keep driving it until it really lets go, taking most everything else with it :cry:
a s/h motor and gearbox will be cheap and easy to swap over in a day
PostPosted: Sat Jan 28, 2006 12:47 am
have we forgoten??
when you restore the engine you do the gear box!!
i did say im going 1275, so im not fussed about the tired old 998 that is basicaly stuffed anyway.
PostPosted: Sat Jan 28, 2006 12:53 am
you said it still goes strong,
does it make a knocking/tapping/slapping sound?
i wouldnt keep driving it if it was farked,
i had a similar situation, and i just bought another ok smallbore for cheap
PostPosted: Sat Jan 28, 2006 1:00 am
revs smooth....only starts slapping when plug fouls...rev it up and it sorts out the plug...if not i take out the plug and clean it
I have never replaced a mini engine. i dont know how.
PostPosted: Sat Jan 28, 2006 1:04 am
as a temporary measure, run a hotter plug on that piston,
but swapping a motor is really easy, you just need someone who has done it to tell you each step, but motor out and new one installed in a day
mini mechanics boast of being able to get a motor out in 30 mins
PostPosted: Sat Jan 28, 2006 3:04 pm
At the moment im using 12NYC plugs...champions...dont think they help all that much.
but nevermind.
PostPosted: Sat Jan 28, 2006 3:19 pm
try some bosch BP7ES plugs. they stopped my old engine fouling.
lookin for another clubby
PostPosted: Sat Jan 28, 2006 4:21 pm
That is an NGK number and COLDER than STD!
I run them on track days...:)
Users browsing this forum: No registered users and 303 guests
